Introdução
The guide will detail the replacement of the back panel of the HP 15-BA078DX.
O que você precisa
Unclip the two latches on the bottom of the laptop.
Slide the battery straight out while holding the clip open.
Using the Phillips #0 screwdriver, remove the 7.5mm screw from the underside of the plastic frame that holds the disc tray in place.
Remove all of the remaining back panel screws with a #0 Phillips head screwdriver.
Um comentário
Thank you so much! I know I am probably the only or one of the few people to write a comment for this specific laptop but I wanted to upgrade the RAM and HDD to SSD. Have a great day
