Ir para o conteúdo principal
HP 15-AF131DX Trackpad Button Circuit Board Replacement
O que você precisa
  1. HP 15-AF131DX Trackpad Button Circuit Board Replacement, Battery: passo 1, imagem 1 %32 HP 15-AF131DX Trackpad Button Circuit Board Replacement, Battery: passo 1, imagem 2 %32
    • Turn the computer upside down on a level surface.
    • Slide the battery lock to unlock the battery.
    • Slide the battery release latch. The latch will click when the battery is released.
    • Lift the battery from the middle to remove it from the computer.
    • The latch will click again when a battery is reinstalled. Switch the battery lock back to locked after reinstalling a battery to keep it secure.
  2. HP 15-AF131DX Trackpad Button Circuit Board Replacement, Optical Drive: passo 2, imagem 1 %32 HP 15-AF131DX Trackpad Button Circuit Board Replacement, Optical Drive: passo 2, imagem 2 %32
    • Using a small Phillips screwdriver, remove the Phillips screw in the middle of the bottom of the computer.
    • Pull the CD/DVD drive outward to slide it away from the computer.
  3. HP 15-AF131DX Trackpad Button Circuit Board Replacement: passo 3, imagem 1 %32
    • To open the drive use an unbent paperclip and press it into the small hole until the disc tray releases.
    • Pull the disc tray out from the front until it is as far as it will go out of the optical drive.
  4. HP 15-AF131DX Trackpad Button Circuit Board Replacement: passo 4, imagem 1 %32 HP 15-AF131DX Trackpad Button Circuit Board Replacement: passo 4, imagem 2 %32 HP 15-AF131DX Trackpad Button Circuit Board Replacement: passo 4, imagem 3 %32
    • To remove excess parts from the optical drive press down on the plastic tab behind the tray's bezel.
    • Gently pry the bezel from the face of the optical drive.
    • With a smaller phillips head screwdriver, remove the screws on the back of the drive, then remove the small metal bracket.
  5. HP 15-AF131DX Trackpad Button Circuit Board Replacement, Trackpad Button Circuit Board: passo 5, imagem 1 %32 HP 15-AF131DX Trackpad Button Circuit Board Replacement, Trackpad Button Circuit Board: passo 5, imagem 2 %32
    • Remove two rubber feet by peeling them off.
    • Remove twelve Phillips head 8.8mm screws using the Phillips #0 Screwdriver.
  6. HP 15-AF131DX Trackpad Button Circuit Board Replacement: passo 6, imagem 1 %32 HP 15-AF131DX Trackpad Button Circuit Board Replacement: passo 6, imagem 2 %32 HP 15-AF131DX Trackpad Button Circuit Board Replacement: passo 6, imagem 3 %32
    • Remove the bottom of the plastic case using a blue plastic opening tool.
    • The Trackpad Button Circuit Board is found in the red box.
  7. HP 15-AF131DX Trackpad Button Circuit Board Replacement: passo 7, imagem 1 %32 HP 15-AF131DX Trackpad Button Circuit Board Replacement: passo 7, imagem 2 %32
    • Remove the two 3.3mm Phillips-head screws that secure the trackpad circuit board to the top cover.
  8. HP 15-AF131DX Trackpad Button Circuit Board Replacement: passo 8, imagem 1 %32 HP 15-AF131DX Trackpad Button Circuit Board Replacement: passo 8, imagem 2 %32
    Ferramenta utilizada nesse passo:
    Comprar
    • Lift the plastic wire lock bracket.
    • Pull on the blue tab to remove the wire using the tweezers tool to make sure there is no damage as you pull.
  9. HP 15-AF131DX Trackpad Button Circuit Board Replacement: passo 9, imagem 1 %32 HP 15-AF131DX Trackpad Button Circuit Board Replacement: passo 9, imagem 2 %32
    • Lift the second plastic wire lock bracket.
    • Pull on the purple tab using tweezers to remove the wire.
  10. HP 15-AF131DX Trackpad Button Circuit Board Replacement: passo 10, imagem 1 %32
    • Lift and remove the trackpad button circuit board.
Conclusão
Adrianna
Membro desde: 11/01/18
133 Reputação
Autoria de 1 guia
Equipe
IUPUI, Team S2-G2, Harley Fall 2018 Membro de IUPUI, Team S2-G2, Harley Fall 2018
IUPUI-HARLEY-F18S2G2
Membros da 3
Autoria de 2 guias
0 comentários
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 0
Últimos 7 dias: 1
Últimos 30 dias: 3
Duração total: 358
