Ir para o conteúdo principal
HP 15-AF131DX Speaker Replacement
O que você precisa
  1. HP 15-AF131DX Speaker Replacement, Speakers: passo 1, imagem 1 %32 HP 15-AF131DX Speaker Replacement, Speakers: passo 1, imagem 2 %32
    • Use a Phillips screwdriver to remove the 10 visible screws on the bottom.
    • Peel up the rubber feet near the hinges.
    • Remove the screw under each.
  2. HP 15-AF131DX Speaker Replacement: passo 2, imagem 1 %32 HP 15-AF131DX Speaker Replacement: passo 2, imagem 2 %32
    Ferramenta utilizada nesse passo:
    Plastic Cards
    $2.99
    Comprar
    • Turn the computer over and use a plastic card, opening pick, or opening tool to pry the space between the keyboard and bottom surface of the computer.
    • Work plastic card, opening pick, or opening tool carefully around the three edges (excluding the side with the screen, which should be positioned at 90 degrees.
    • Gently lift the top surface of the bottom half of the laptop, revealing the speakers.
  3. HP 15-AF131DX Speaker Replacement: passo 3, imagem 1 %32 HP 15-AF131DX Speaker Replacement: passo 3, imagem 2 %32 HP 15-AF131DX Speaker Replacement: passo 3, imagem 3 %32
    • Pull up on each individual speaker, removing the rubber holds from their plastic pins.
    • Unplug the wire that connects the speakers.
    • Carefully remove the speakers from their plastic holds.
Conclusão
Anthony Martinez
Membro desde: 10/05/17
526 Reputação
Autoria de 3 guias
Equipe
Cal Poly, Team S6-G2, Banghart Fall 2017 Membro de Cal Poly, Team S6-G2, Banghart Fall 2017
CPSU-BANGHART-F17S6G2
Membros da 5
Autoria de 5 guias
0 comentários
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 0
Últimos 7 dias: 1
Últimos 30 dias: 5
Duração total: 635
