Ir para o conteúdo principal
HP 15-AF131DX Optical Drive Replacement
O que você precisa
  1. HP 15-AF131DX Optical Drive Replacement, Optical Drive: passo 1, imagem 1 %32 HP 15-AF131DX Optical Drive Replacement, Optical Drive: passo 1, imagem 2 %32
    • Using a small Phillips screwdriver, remove the Phillips screw in the middle of the bottom of the computer.
    • Pull the CD/DVD drive outward to slide it away from the computer.
  2. HP 15-AF131DX Optical Drive Replacement: passo 2, imagem 1 %32
    • To open the drive use an unbent paperclip and press it into the small hole until the disc tray releases.
    • Pull the disc tray out from the front until it is as far as it will go out of the optical drive.
  3. HP 15-AF131DX Optical Drive Replacement: passo 3, imagem 1 %32 HP 15-AF131DX Optical Drive Replacement: passo 3, imagem 2 %32 HP 15-AF131DX Optical Drive Replacement: passo 3, imagem 3 %32
    • To remove excess parts from the optical drive press down on the plastic tab behind the tray's bezel.
    • Gently pry the bezel from the face of the optical drive.
    • With a smaller phillips head screwdriver, remove the screws on the back of the drive, then remove the small metal bracket.
Conclusão
Uma outra pessoa concluiu este guia.
Equipe
Cal Poly, Team S6-G2, Banghart Fall 2017 Membro de Cal Poly, Team S6-G2, Banghart Fall 2017
CPSU-BANGHART-F17S6G2
Membros da 5
Autoria de 5 guias
0 comentários
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 0
Últimos 7 dias: 1
Últimos 30 dias: 7
Duração total: 472
