Ir para o conteúdo principal
HP 15-AF131DX Hard Drive Replacement
O que você precisa
  1. HP 15-AF131DX Hard Drive Replacement, Hard Drive: passo 1, imagem 1 %32 HP 15-AF131DX Hard Drive Replacement, Hard Drive: passo 1, imagem 2 %32
    • Use a Phillips screwdriver to remove the 10 visible screws on the bottom.
    • Peel up the rubber feet near the hinges.
    • Remove the screw under each.
  2. HP 15-AF131DX Hard Drive Replacement: passo 2, imagem 1 %32 HP 15-AF131DX Hard Drive Replacement: passo 2, imagem 2 %32
    Ferramenta utilizada nesse passo:
    Plastic Cards
    $2.99
    Comprar
    • Turn the computer over and use a plastic card, opening pick, or opening tool to pry the space between the keyboard and bottom surface of the computer.
    • Work plastic card, opening pick, or opening tool carefully around the three edges (excluding the side with the screen, which should be positioned at 90 degrees.
    • Gently lift the top surface of the bottom half of the laptop, revealing the hard drive.
  3. HP 15-AF131DX Hard Drive Replacement: passo 3, imagem 1 %32 HP 15-AF131DX Hard Drive Replacement: passo 3, imagem 2 %32 HP 15-AF131DX Hard Drive Replacement: passo 3, imagem 3 %32
    • Remove the three screws that hold the hard drive in place.
    • Lift the hard drive slightly and disconnect the SATA hard drive connector to free the hard drive.
    • Remove the hard drive.
Conclusão
8 outras pessoas executaram este guia.
Anthony Martinez
Membro desde: 10/05/17
526 Reputação
Autoria de 3 guias
Equipe
Cal Poly, Team S6-G2, Banghart Fall 2017 Membro de Cal Poly, Team S6-G2, Banghart Fall 2017
CPSU-BANGHART-F17S6G2
Membros da 5
Autoria de 5 guias
0 comentários
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 0
Últimos 7 dias: 2
Últimos 30 dias: 9
Duração total: 5,446
