Ir para o conteúdo principal
HP 14-am052nr Motherboard Replacement
O que você precisa
  1. HP 14-am052nr Motherboard Replacement, Battery: passo 1, imagem 1 %32 HP 14-am052nr Motherboard Replacement, Battery: passo 1, imagem 2 %32 HP 14-am052nr Motherboard Replacement, Battery: passo 1, imagem 3 %32
    • Turn the laptop over to its bottom so that the backside is facing you.
    • Using your fingers, push the two locking tabs inwards to release the battery.
    • Remove the battery from the device.
  2. HP 14-am052nr Motherboard Replacement, Back Panel: passo 2, imagem 1 %32 HP 14-am052nr Motherboard Replacement, Back Panel: passo 2, imagem 2 %32
    • After removing the battery with the laptop on its back, expose screws that are hidden under the rubber feet and the center label.
    • Using the Phillips #0 screwdriver, remove fourteen (14) 6 mm screws from the back panel.
  3. HP 14-am052nr Motherboard Replacement: passo 3, imagem 1 %32 HP 14-am052nr Motherboard Replacement: passo 3, imagem 2 %32
    • Use a prying tool to remove the back panel from the base of the computer.
  4. HP 14-am052nr Motherboard Replacement, Motherboard: passo 4, imagem 1 %32
    • Using the Phillips #0 screwdriver, remove three 3 mm screws and five 3.5 mm screws from the motherboard.
  5. HP 14-am052nr Motherboard Replacement: passo 5, imagem 1 %32 HP 14-am052nr Motherboard Replacement: passo 5, imagem 2 %32
    • Using the Phillips #0 screwdriver, remove four 1.5 mm screws from the silver cover.
    • Remove the silver cover from the device.
  6. HP 14-am052nr Motherboard Replacement: passo 6, imagem 1 %32 HP 14-am052nr Motherboard Replacement: passo 6, imagem 2 %32 HP 14-am052nr Motherboard Replacement: passo 6, imagem 3 %32
    • Unplug all connectors attached to the motherboard.
  7. HP 14-am052nr Motherboard Replacement: passo 7, imagem 1 %32
    • Once all plugs and screws disconnected, remove the motherboard from the device.
Conclusão
Matthew Heather
Membro desde: 11/03/21
379 Reputação
Autoria de 4 guias
Equipe
UMass Dartmouth, Team 3-3, Sinclaire Fall 2021 Membro de UMass Dartmouth, Team 3-3, Sinclaire Fall 2021
UMASSD-SINCLAIRE-F21S3G3
Membros da 3
Autoria de 7 guias
0 comentários
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 0
Últimos 7 dias: 4
Últimos 30 dias: 21
Duração total: 323
