Introdução
Sometimes a devices battery has been recharged too many times. This recharging causes the battery to diminish over time and hold less of a charge. The purpose of this guide is to demonstrate how to replace a bad or warn battery on the HMDX Jam Plus.
O que você precisa
Flip the device over so the bottom is facing up.
Use the large plastic opening tool to gently pry the rubber base from the device.
Slowly move the plastic opening tool around the edge of the rubber base to separate it from the plastic.
4 outras pessoas executaram este guia.
5 comentários
Where may battery be purchased?
Thanks,
zappenfusen
Where to purchase battery for hmdx jam speaker
Where can a battery be purchased?
What kind (especifications) that battery?
Where to buy battery for HMDX JAM.Bluetooth speaker
