Ir para o conteúdo principal
HMDX Jam Plus Battery Replacement
O que você precisa
  1. HMDX Jam Plus Battery Replacement, Battery: passo 1, imagem 1 %32 HMDX Jam Plus Battery Replacement, Battery: passo 1, imagem 2 %32 HMDX Jam Plus Battery Replacement, Battery: passo 1, imagem 3 %32
    • Flip the device over so the bottom is facing up.
    • Use the large plastic opening tool to gently pry the rubber base from the device.
    • Slowly move the plastic opening tool around the edge of the rubber base to separate it from the plastic.
  2. HMDX Jam Plus Battery Replacement: passo 2, imagem 1 %32 HMDX Jam Plus Battery Replacement: passo 2, imagem 2 %32
    • Use a Phillips #1 screwdriver to remove the four black 9mm screws from the device.
  3. HMDX Jam Plus Battery Replacement: passo 3, imagem 1 %32 HMDX Jam Plus Battery Replacement: passo 3, imagem 2 %32
    • Gently separate the base from the rest of the device to reveal the battery and the main board.
  4. HMDX Jam Plus Battery Replacement: passo 4, imagem 1 %32 HMDX Jam Plus Battery Replacement: passo 4, imagem 2 %32 HMDX Jam Plus Battery Replacement: passo 4, imagem 3 %32
    • Carefully use the plastic opening tool to remove the glue around the battery and speaker connectors.
    • Pull gently on the connectors to separate each one from the main board.
    • The battery is connected to board in the red socket and the speaker is connected in the white socket.
  5. HMDX Jam Plus Battery Replacement: passo 5, imagem 1 %32 HMDX Jam Plus Battery Replacement: passo 5, imagem 2 %32 HMDX Jam Plus Battery Replacement: passo 5, imagem 3 %32
    • Batteries can be very dangerous if punctured. Use extra caution when using tools around the battery.
    • Use the plastic opening tool to gently pry the battery free from the rest of the device.
  6. HMDX Jam Plus Battery Replacement: passo 6, imagem 1 %32 HMDX Jam Plus Battery Replacement: passo 6, imagem 2 %32
    • Use new adhesive to secure battery back to the rest of the device.
Conclusão
4 outras pessoas executaram este guia.
Maxwell Erickson
Membro desde: 10/22/15
587 Reputação
Autoria de 4 guias
Equipe
Montana Tech, Team 10-3, Shirk Fall 2015 Membro de Montana Tech, Team 10-3, Shirk Fall 2015
MTUM-SHIRK-F15S10G3
Membros da 4
Autoria de 4 guias
6 comentários
Where may battery be purchased?
Thanks,
zappenfusen
warnsdorff - Responder
Where to purchase battery for hmdx jam speaker
Frank David -
Where can a battery be purchased?
robertwacker - Responder
What kind (especifications) that battery?
vecchio.farias - Responder
Where to buy battery for HMDX JAM.Bluetooth speaker
Frank David - Responder
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 0
Últimos 7 dias: 4
Últimos 30 dias: 37
Duração total: 7,173
