Ir para o conteúdo principal
HKC P776A Wifi Antenna Replacement
O que você precisa
  1. HKC P776A Wifi Antenna Replacement, Separating Digitizer and Case: passo 1, imagem 1 %32
    • Insert the plastic opening tool between the digitizer and the case.
    • Place the spudger in the gap created by the plastic opening tool to assist in separation.
  2. HKC P776A Wifi Antenna Replacement: passo 2, imagem 1 %32 HKC P776A Wifi Antenna Replacement: passo 2, imagem 2 %32
    • Slide the spudger along the perimeter of the device to fully separate the two pieces.
  3. HKC P776A Wifi Antenna Replacement, Wifi Antenna: passo 3, imagem 1 %32 HKC P776A Wifi Antenna Replacement, Wifi Antenna: passo 3, imagem 2 %32
    • Peel off the tape that is attaching the wifi antenna to the case.
  4. HKC P776A Wifi Antenna Replacement: passo 4, imagem 1 %32
    • Using the soldering iron, heat up the solder that is attaching the antenna to the motheboard.
    • The heat from the soldering iron may cause personal injury or damage the internal components of the tablet.
  5. HKC P776A Wifi Antenna Replacement: passo 5, imagem 1 %32
    Ferramenta utilizada nesse passo:
    Desoldering Pump
    $3.99
    Comprar
    • Suck up the leftover solder using the desoldering pump.
    • Remove the wifi antenna from the motherboard.
Conclusão
Ryan Gornati
Membro desde: 01/22/15
409 Reputação
Autoria de 4 guias
Equipe
USF Tampa, Team 7-6, Remmell Winter 2015 Membro de USF Tampa, Team 7-6, Remmell Winter 2015
USFT-REMMELL-W15S7G6
Membros da 3
Autoria de 14 guias
0 comentários
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 3
Últimos 7 dias: 4
Últimos 30 dias: 11
Duração total: 131
