Ir para o conteúdo principal
HKC P776A Digitizer Replacement
O que você precisa
  1. HKC P776A Digitizer Replacement, Separating Digitizer and Case: passo 1, imagem 1 %32
    • Insert the plastic opening tool between the digitizer and the case.
    • Place the spudger in the gap created by the plastic opening tool to assist in separation.
  2. HKC P776A Digitizer Replacement: passo 2, imagem 1 %32 HKC P776A Digitizer Replacement: passo 2, imagem 2 %32
    • Slide the spudger along the perimeter of the device to fully separate the two pieces.
  3. HKC P776A Digitizer Replacement, Separating the Screen and the Digitizer: passo 3, imagem 1 %32 HKC P776A Digitizer Replacement, Separating the Screen and the Digitizer: passo 3, imagem 2 %32
    • Use your fingers to pop the screen out from the digitizer.
  4. HKC P776A Digitizer Replacement, Removing the Cable from the Motherboard: passo 4, imagem 1 %32 HKC P776A Digitizer Replacement, Removing the Cable from the Motherboard: passo 4, imagem 2 %32
    • Use the tip of the spudger to release the latches on the motherboard.
  5. HKC P776A Digitizer Replacement: passo 5, imagem 1 %32
    • Remove the cable from the motherboard.
Conclusão
Spencer Pheasant
Membro desde: 01/20/15
301 Reputação
Autoria de 3 guias
Equipe
USF Tampa, Team 7-6, Remmell Winter 2015 Membro de USF Tampa, Team 7-6, Remmell Winter 2015
USFT-REMMELL-W15S7G6
Membros da 3
Autoria de 14 guias
0 comentários
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 1
Últimos 7 dias: 4
Últimos 30 dias: 4
Duração total: 132
