Ir para o conteúdo principal
HKC P776A Battery Replacement
O que você precisa
  1. HKC P776A Battery Replacement, Separating Digitizer and Case: passo 1, imagem 1 %32
    • Insert the plastic opening tool between the digitizer and the case.
    • Place the spudger in the gap created by the plastic opening tool to assist in separation.
  2. HKC P776A Battery Replacement: passo 2, imagem 1 %32 HKC P776A Battery Replacement: passo 2, imagem 2 %32
    • Slide the spudger along the perimeter of the device to fully separate the two pieces.
  3. HKC P776A Battery Replacement, Battery: passo 3, imagem 1 %32
    • Insert the plastic opening tool between the battery and case.
    • Apply leverage to break the glue that is attaching the battery to the case.
  4. HKC P776A Battery Replacement: passo 4, imagem 1 %32
    • Continue breaking the glue along the perimeter of the battery until the battery can be removed.
    • Breaking all the glue between the battery and case may take a long time.
  5. HKC P776A Battery Replacement: passo 5, imagem 1 %32 HKC P776A Battery Replacement: passo 5, imagem 2 %32
    • Using the soldering iron, heat up the solder that is attaching the battery to the motheboard.
    • The heat from the soldering iron may cause personal injury or damage the internal components of the tablet.
  6. HKC P776A Battery Replacement: passo 6, imagem 1 %32
    • Suck up the leftover solder using the desoldering pump.
    • Remove the battery from the motherboard.
Conclusão
Ryan Gornati
Membro desde: 01/22/15
409 Reputação
Autoria de 4 guias
Equipe
USF Tampa, Team 7-6, Remmell Winter 2015 Membro de USF Tampa, Team 7-6, Remmell Winter 2015
USFT-REMMELL-W15S7G6
Membros da 3
Autoria de 14 guias
0 comentários
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 1
Últimos 7 dias: 2
Últimos 30 dias: 8
Duração total: 641
