Introdução
The LCD screen is what projects information from the tablet. This is not to be confused with the digitizer (see digitizer replacement guide). On this tablet, the LCD screen is on the inside of the device.
O que você precisa
Insert the flat end of the spudger into the side of the device
This will create a gap between the device and screen housing.
Insert the plastic opening tool into this gap and move it along this gap.
The screen housing and device will now be separated.
Once the digitizer has been removed, the LCD can be disconnected from the motherboard.
Use the tweezers to unlock the black pins (outlined in red) that connect the LCD band to the motherboard.
Once the pins have been removed, pull the band out using the tweezers.
Uma outra pessoa concluiu este guia.
