Introdução
The digitizer is the part that fits in front the LCD. This is records touch feedback.
O que você precisa
Insert the flat end of the spudger into the side of the device
This will create a gap between the device and screen housing.
Insert the plastic opening tool into this gap and move it along this gap.
The screen housing and device will now be separated.
Ferramenta utilizada nesse passo:Tweezers$4.99
Once the digitizer has been been removed from the body, disconnect the digitizer band from the motherboard.
Two small black pins (circled in red) will need to be unlocked.
Unlock the pins by pulling them outward with the tweezers.
Remove the band using the tweezers.
Uma outra pessoa concluiu este guia.
