Ir para o conteúdo principal
HKC P771A Digitizer Replacement
O que você precisa
  1. HKC P771A Digitizer Replacement, Digitizer: passo 1, imagem 1 %32 HKC P771A Digitizer Replacement, Digitizer: passo 1, imagem 2 %32
    • Remove back of tablet using the plastic opening tool
    • Slide the opening tool between the back of the tablet and the digitizer
    • Lift along the edges until the back of the tablet and the digitizer are separated
  2. HKC P771A Digitizer Replacement: passo 2, imagem 1 %32 HKC P771A Digitizer Replacement: passo 2, imagem 2 %32
    • Remove 4 screws located on the red motherboard
    • The red motherboard will be loose, but does not need to come completely unattached
  3. HKC P771A Digitizer Replacement: passo 3, imagem 1 %32
    • Remove 7 screws located around the edges of the tablet
    • 5 screws are visible around the edges of the device and 2 screws are located underneath the red motherboard
  4. HKC P771A Digitizer Replacement: passo 4, imagem 1 %32
    • Lift digitizer from the screen
    • After removing all of the screws, the screen should easily separate from the digitizer
  5. HKC P771A Digitizer Replacement: passo 5, imagem 1 %32
    • Now you can replace the old digitizer with a new one
Conclusão
Sara Hill
Membro desde: 09/30/15
101 Reputação
Autoria de 2 guias
Equipe
Ohio State, Team 2-3, Garvin Fall 2015 Membro de Ohio State, Team 2-3, Garvin Fall 2015
OSU-GARVIN-F15S2G3
Membros da 4
Autoria de 4 guias
0 comentários
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 1
Últimos 7 dias: 1
Últimos 30 dias: 4
Duração total: 264
