Ir para o conteúdo principal
HKC P771A Camera Replacement
O que você precisa
  1. HKC P771A Camera Replacement, Camera: passo 1, imagem 1 %32 HKC P771A Camera Replacement, Camera: passo 1, imagem 2 %32 HKC P771A Camera Replacement, Camera: passo 1, imagem 3 %32
    • Remove back of tablet using the plastic opening tool
    • Slide the opening tool between the back of the tablet and the digitizer
    • Lift along the edges until the back of the tablet and the digitizer are separated
  2. HKC P771A Camera Replacement: passo 2, imagem 1 %32 HKC P771A Camera Replacement: passo 2, imagem 2 %32
    • Remove yellow tape around the edges of the battery
    • The battery is located on the right side of the tablet when the screen is facing downwards and the camera is on top
  3. HKC P771A Camera Replacement: passo 3, imagem 1 %32 HKC P771A Camera Replacement: passo 3, imagem 2 %32 HKC P771A Camera Replacement: passo 3, imagem 3 %32
    • Pry battery away from the back of the tablet until the battery is completely separated from the adhesive
  4. HKC P771A Camera Replacement: passo 4, imagem 1 %32
    • Remove yellow tape that is securing the camera wires
  5. HKC P771A Camera Replacement: passo 5, imagem 1 %32 HKC P771A Camera Replacement: passo 5, imagem 2 %32
    • Remove silver foil from the back of the camera using the blue opening tool
  6. HKC P771A Camera Replacement: passo 6, imagem 1 %32
    • Lift the bronze, L-shaped ribbon
    • The camera is attached to the end of this ribbon so it will move with it
  7. HKC P771A Camera Replacement: passo 7, imagem 1 %32
    • Flip up the black bar located on the motherboard
    • The black bar is to the left of the camera, where the ribbon is attached to the motherboard
  8. HKC P771A Camera Replacement: passo 8, imagem 1 %32
    • Remove the bronze, L-shaped ribbon from inside the black bar
  9. HKC P771A Camera Replacement: passo 9, imagem 1 %32
    • Your camera is now removed from the tablet
Conclusão
Sara Hill
Membro desde: 09/30/15
101 Reputação
Autoria de 2 guias
Equipe
Ohio State, Team 2-3, Garvin Fall 2015 Membro de Ohio State, Team 2-3, Garvin Fall 2015
OSU-GARVIN-F15S2G3
Membros da 4
Autoria de 4 guias
0 comentários
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 0
Últimos 7 dias: 1
Últimos 30 dias: 1
Duração total: 168
