Ir para o conteúdo principal
Gyroscopic exercise tool (Powerball) Roller Fix
O que você precisa
  1. Gyroscopic exercise tool (Powerball) Roller Fix, Remove rubber band: passo 1, imagem 1 %32
    • Remove rubber band.
  2. Gyroscopic exercise tool (Powerball) Roller Fix, Unscrew holdings: passo 2, imagem 1 %32
    • Find two small Phillips screws holding both housing halves and unscrew them.
  3. Gyroscopic exercise tool (Powerball) Roller Fix, Split housing: passo 3, imagem 1 %32
    • Use some flat tool, I used small blade of my Swiss Army knife but spudger should be a better choice. Pry one half from the other. You will hear loud click and then it should open.
  4. Gyroscopic exercise tool (Powerball) Roller Fix, Open housing: passo 4, imagem 1 %32 Gyroscopic exercise tool (Powerball) Roller Fix, Open housing: passo 4, imagem 2 %32 Gyroscopic exercise tool (Powerball) Roller Fix, Open housing: passo 4, imagem 3 %32
    • Remove gyro. It’s connected to white plastic roundel which really is a part of inner bearing. It slides on the both sides of housing.
  5. Gyroscopic exercise tool (Powerball) Roller Fix, Identify deflections: passo 5, imagem 1 %32
    • Look at these surfaces and you will find several small deflections. They were made by gyro’s axis when it hit the floor. These deflections put up resistance during rolling and this is the reason it’s so hard to spin device.
  6. Gyroscopic exercise tool (Powerball) Roller Fix, Fill deflections with glue: passo 6, imagem 1 %32
    • You have to fill them with Superglue or other cyanoacrylate glue. Fill them and wait for around 20 minutes.
    • Caution: check if glue you use is OK, try it on some hidden area of housing.
  7. Gyroscopic exercise tool (Powerball) Roller Fix, Make it smooth: passo 7, imagem 1 %32
    • Use some sharp tool and remove surpluses, make these places as smooth as you can. From time to time put gyro back in place and roll it on both halves of housing until you’ll feel it’s enough.
  8. Gyroscopic exercise tool (Powerball) Roller Fix, Put it back: passo 8, imagem 1 %32
    • Put whole device back in reverse order and test it. The more you will spin it, the smoother it will work. The best thing is: you can fix it over and over again and you don’t have to pay again.
Conclusão
paczor
Membro desde: 04/22/10
758 Reputação
Autoria de 1 guia
0 comentários
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 4
Últimos 7 dias: 15
Últimos 30 dias: 58
Duração total: 3,886
