Ir para o conteúdo principal
Grip Tape Application
O que você precisa
  1. Grip Tape Application, Grip Tape Application: passo 1, imagem 1 %32
    • Peel off the paper backing from the sheet of grip tape.
    • Make sure you do not fold or wrinkle the grip tape.
  2. Grip Tape Application: passo 2, imagem 1 %32
    • Center the sheet of grip tape evenly over the top of the skateboard deck.
  3. Grip Tape Application: passo 3, imagem 1 %32 Grip Tape Application: passo 3, imagem 2 %32
    • Starting from the very middle and moving outward, firmly press down on the grip tape while smoothing out any air bubbles that start to form.
  4. Grip Tape Application: passo 4, imagem 1 %32 Grip Tape Application: passo 4, imagem 2 %32
    • Use a screwdriver to scrape along the edges of the skateboard. This will remove some of the grip around the edges making the trimming process easier on you and your equipment.
    • You can use the utility knife to cut a perpendicular line in the excess grip tape if it is resisting the screwdriver too much.
  5. Grip Tape Application: passo 5, imagem 1 %32 Grip Tape Application: passo 5, imagem 2 %32 Grip Tape Application: passo 5, imagem 3 %32
    • Use a utility knife to begin cutting around the edge of your skateboard to remove excess grip tape.
    • Angle your knife towards the inside of the skateboard to make it easier to cut a straight line.
    • Be careful when using the utility knife and always keep it pointed away from yourself and others.
  6. Grip Tape Application: passo 6, imagem 1 %32
    • Once you have removed all of the excess grip tape, you can use the scraps to sand the edges of your cut to smooth out any small inconsistencies.
    • Use caution when sanding as the grip tape can become heated.
  7. Grip Tape Application: passo 7, imagem 1 %32
    • If air bubbles persist, gently use a utility knife to poke a small hole in the grip tape at the center of the bubble and press out the air.
  8. Grip Tape Application: passo 8, imagem 1 %32 Grip Tape Application: passo 8, imagem 2 %32
    • After you have finished applying your grip tape, you can use a small screwdriver to poke holes where your truck hardware will be installed.
Conclusão
The next logical step in the assembly of a skateboard is to install skateboard trucks, please reference the Truck Installation guide.
4 outras pessoas executaram este guia.
Jared Stine
Membro desde: 10/05/12
800 Reputação
Autoria de 3 guias
Equipe
Cal Poly, Team 6-32, Regan Fall 2012 Membro de Cal Poly, Team 6-32, Regan Fall 2012
CPSU-REGAN-F12S6G32
Membros da 5
Autoria de 6 guias
0 comentários
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 0
Últimos 7 dias: 2
Últimos 30 dias: 5
Duração total: 8,023
