Ir para o conteúdo principal
Griffin iFM 4027 Left Side Panel Replacement
O que você precisa
  1. Griffin iFM 4027 Left Side Panel Replacement, Left Side Panel: passo 1, imagem 1 %32
    • Lodge the tip of the plastic opening tool into the top arc where the side and main part of the device meet.
    • Push the plastic opening tool upward until the side panel detaches.
  2. Griffin iFM 4027 Left Side Panel Replacement: passo 2, imagem 1 %32 Griffin iFM 4027 Left Side Panel Replacement: passo 2, imagem 2 %32 Griffin iFM 4027 Left Side Panel Replacement: passo 2, imagem 3 %32
    • Slide the plastic opening tool along the panel seam and push upward until the side panel detaches from the main device.
    • Turn over the detached side panel, so that the outer side is facing downward.
    • Then use your fingers to disassemble the panel button and set it off to the side.
Conclusão
Alexander
Membro desde: 03/09/12
101 Reputação
Autoria de 6 guias
Equipe
Clemson, Team 15-3, Benson Spring 2012 Membro de Clemson, Team 15-3, Benson Spring 2012
CLEM-BENSON-S12S15G3
Membros da 3
Autoria de 6 guias
0 comentários
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 0
Últimos 7 dias: 7
Últimos 30 dias: 14
Duração total: 1,132
