Ir para o conteúdo principal
GravityLight Internal Gears Replacement
O que você precisa
  1. GravityLight Internal Gears Replacement, Removing the Front Panel: passo 1, imagem 1 %32 GravityLight Internal Gears Replacement, Removing the Front Panel: passo 1, imagem 2 %32
    • Flip the GravityLight on its back and place it on a sturdy surface.
    • Unscrew the three 2cm Phillips #00 screws on the back of the GravityLight’s body.
  2. GravityLight Internal Gears Replacement, Opening the Device Housing: passo 2, imagem 1 %32
    • Some of the internal pieces may loosen or fall out during disassembly.
    • Firmly grasp both parts of the GravityLight body and pull them apart.
  3. GravityLight Internal Gears Replacement, Isolating the Back Panel: passo 3, imagem 1 %32
    • Take the thicker of the two parts, the back piece, and place it face down on a sturdy surface.
  4. GravityLight Internal Gears Replacement, Removing the Back Panel Screws: passo 4, imagem 1 %32
    • Place the back panel, the larger of the two pieces, on a sturdy surface with its back down.
    • Unscrew the two 2cm Phillips 00 screws on the inside of the back panel.
  5. GravityLight Internal Gears Replacement, Removing the LED Housing: passo 5, imagem 1 %32
    • Watch out for the wires! Keep them attached for this entire guide, or the GravityLight will not work!
    • Gently lift off the LED housing (the white disk).
    • Set the LED housing on the table next to the body of the device.
  6. GravityLight Internal Gears Replacement, Removing White Frame and Gear: passo 6, imagem 1 %32
    • Lift off the white piece with four arms.
    • Lift off the black-rimmed gear.
    • Set both pieces aside in a safe place.
  7. GravityLight Internal Gears Replacement, Removing Internal Gears: passo 7, imagem 1 %32 GravityLight Internal Gears Replacement, Removing Internal Gears: passo 7, imagem 2 %32
    • Lift off the three 3.5cm diameter gears.
    • Replace any stripped gears.
Conclusão
Michallynn Hoffman
Membro desde: 09/26/14
317 Reputação
Autoria de 3 guias
Equipe
Cal Poly, Team 12-2, Forte Fall 2014 Membro de Cal Poly, Team 12-2, Forte Fall 2014
CPSU-FORTE-F14S12G2
Membros da 5
Autoria de 7 guias
Um comentário
Where can we find the replacement gears?
fb - Responder
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 0
Últimos 7 dias: 2
Últimos 30 dias: 4
Duração total: 3,028
