Ir para o conteúdo principal
Graco Secure Coverage Parent Unit Battery Replacement
O que você precisa
  1. Graco Secure Coverage Parent Unit Battery Replacement, Parent Unit Battery: passo 1, imagem 1 %32 Graco Secure Coverage Parent Unit Battery Replacement, Parent Unit Battery: passo 1, imagem 2 %32 Graco Secure Coverage Parent Unit Battery Replacement, Parent Unit Battery: passo 1, imagem 3 %32
    • Using plastic opening tool, pry and remove the battery lid.
  2. Graco Secure Coverage Parent Unit Battery Replacement: passo 2, imagem 1 %32
    • Remove the battery by holding the device with one hand and pulling the battery out with other hand carefully.
    • Make sure that you disconnect the battery's wire before you remove the battery.
Conclusão
Rogelio Morales
Membro desde: 08/31/15
201 Reputação
Autoria de 2 guias
Equipe
USF Tampa, Team 6-5, Remmell Fall 2015 Membro de USF Tampa, Team 6-5, Remmell Fall 2015
USFT-REMMELL-F15S6G5
Membros da 4
Autoria de 8 guias
Um comentário
Would anyone happen to know the type of battery needed for the replacement on this baby monitor?
Shaun Barnes (WheelchairShaun) - Responder
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 1
Últimos 7 dias: 5
Últimos 30 dias: 12
Duração total: 709
