Ir para o conteúdo principal
Graco Secure Coverage LED Nursery Unit Replacement
O que você precisa
  1. Graco Secure Coverage LED Nursery Unit Replacement, Nursery Unit Battery: passo 1, imagem 1 %32 Graco Secure Coverage LED Nursery Unit Replacement, Nursery Unit Battery: passo 1, imagem 2 %32 Graco Secure Coverage LED Nursery Unit Replacement, Nursery Unit Battery: passo 1, imagem 3 %32
    • Remove the 9mm screw from the battery cover of the nursery unit using a Phillips #1 tip screwdriver.
  2. Graco Secure Coverage LED Nursery Unit Replacement: passo 2, imagem 1 %32 Graco Secure Coverage LED Nursery Unit Replacement: passo 2, imagem 2 %32
    • Using the plastic opening tool, pry and remove the battery cover carefully.
    • Remove the batteries using plastic opening tool.
    • Replace the batteries.
  3. Graco Secure Coverage LED Nursery Unit Replacement, LED Nursery Unit: passo 3, imagem 1 %32 Graco Secure Coverage LED Nursery Unit Replacement, LED Nursery Unit: passo 3, imagem 2 %32
    • Remove the two 9mm Phillips #1 screws from the rare case of the device.
    • Place the screws in a secure place.
  4. Graco Secure Coverage LED Nursery Unit Replacement: passo 4, imagem 1 %32
    • Hold the bottom of the device with one hand and pull down to separate the front and rare cases.
    • While holding the device with one hand, use plastic opening tool to pry the edges of the front case away from the back case.
    • Apply constant force carefully to avoid breaking any other plastic parts from the device.
  5. Graco Secure Coverage LED Nursery Unit Replacement: passo 5, imagem 1 %32 Graco Secure Coverage LED Nursery Unit Replacement: passo 5, imagem 2 %32
    • Remove all three 7mm Phillips #1 screws from the mother board.
    • Place the screws in secure place.
  6. Graco Secure Coverage LED Nursery Unit Replacement: passo 6, imagem 1 %32 Graco Secure Coverage LED Nursery Unit Replacement: passo 6, imagem 2 %32 Graco Secure Coverage LED Nursery Unit Replacement: passo 6, imagem 3 %32
    • Flip over the motherboard to look at the LED pins that are connected to it.
    • Solder off the LED pin from the motherboard.
    • There are many pins are connect to the motherboard, so make sure that you solder off the LED pin.
    • Replace the LED.
Conclusão
Bryson Wolff
Membro desde: 08/31/15
237 Reputação
Autoria de 2 guias
Equipe
USF Tampa, Team 6-5, Remmell Fall 2015 Membro de USF Tampa, Team 6-5, Remmell Fall 2015
USFT-REMMELL-F15S6G5
Membros da 4
Autoria de 8 guias
0 comentários
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 0
Últimos 7 dias: 1
Últimos 30 dias: 11
Duração total: 162
