Ir para o conteúdo principal
Graco Literider Classic Connect Handle Cover Replacement
O que você precisa
  1. Graco Literider Classic Connect Handle Cover Replacement, Handle Cover: passo 1, imagem 1 %32
    • Flip the stroller over so that the screws on the handle are facing upwards.
    • Locate the four 22 mm Phillips screws on the underside of the handle.
  2. Graco Literider Classic Connect Handle Cover Replacement: passo 2, imagem 1 %32
    • Using a Phillips #1 screwdriver, remove the four 22 mm screws and set them aside.
  3. Graco Literider Classic Connect Handle Cover Replacement: passo 3, imagem 1 %32
    • Push the switch in to allow the handle cover to come free.
  4. Graco Literider Classic Connect Handle Cover Replacement: passo 4, imagem 1 %32
    • Remove the handle cover from the handle.
    • Avoid pushing the two rods fully into the slots on the handle, as they can be very difficult to remove.
Conclusão
Tyler Laird
Membro desde: 09/29/15
540 Reputação
Autoria de 3 guias
Equipe
Cal Poly, Team 11-4, Forte Fall 2015 Membro de Cal Poly, Team 11-4, Forte Fall 2015
CPSU-FORTE-F15S11G4
Membros da 5
Autoria de 3 guias
0 comentários
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 0
Últimos 7 dias: 1
Últimos 30 dias: 4
Duração total: 1,036
