Ir para o conteúdo principal
Grace Digital Mondo Front Panel Replacement
O que você precisa
  1. Grace Digital Mondo Front Panel Replacement, Front Panel: passo 1, imagem 1 %32
    • Remove (2) screws (14 mm) with a PH1 screwdriver on the device.
    • There is one screw on the back left, and another just below it on the bottom of the device.
  2. Grace Digital Mondo Front Panel Replacement: passo 2, imagem 1 %32 Grace Digital Mondo Front Panel Replacement: passo 2, imagem 2 %32
    • Use a plastic spudger to remove the front preset selection buttons.
    • We recommend you remove all of them for easier access.
    • Gently reach underneath and pull off the mesh speaker cover. It only clips in so don't worry about breaking anything.
  3. Grace Digital Mondo Front Panel Replacement: passo 3, imagem 1 %32
    • Remove (4) screws (14 mm) with a PH1 screwdriver on the front panel by the speaker.
    • Be careful with these screws, as they can be stripped easily.
  4. Grace Digital Mondo Front Panel Replacement: passo 4, imagem 1 %32
    • Move the metal spudger around the front panel to remove any adhesive attaching the front panel to the device.
    • Pull apart the front panel from the device with help from the metal spudger.
  5. Grace Digital Mondo Front Panel Replacement: passo 5, imagem 1 %32 Grace Digital Mondo Front Panel Replacement: passo 5, imagem 2 %32 Grace Digital Mondo Front Panel Replacement: passo 5, imagem 3 %32
    • Detach a pin connector at the top of the device using a metal spudger to open up the inner components.
    • Detach (4) pin connectors inside using a metal spudger to separate the front panel from the rest of the device.
Conclusão
3 outras pessoas executaram este guia.
Zachary Nelson
Membro desde: 02/08/16
400 Reputação
Autoria de 3 guias
Equipe
USF Tampa, Team 6-3, Eyestone Spring 2016 Membro de USF Tampa, Team 6-3, Eyestone Spring 2016
USFT-EYESTONE-S16S6G3
Membros da 4
Autoria de 8 guias
3 comentários
The headphone jack opened up on one side so the speaker stopped working. Did not replace defective jack, just shorted together the offending jack pins. Works!
Thanks for showing how to open up this radio!
Alvin Corson - Responder
Excellent guide for removing the front panel. I might not have figured that out without damaging something.
The network connection keeps re-initializing and I was hoping to find maybe a loose wire or something. but alas, I found nothing suspicious and it’s still broke. The IRC6000R isn’t made anymore or serviceable so I guess it’s broke for life. Guess I’ll have to replace it, not sure about Grade Digital anymore.
BTW… My Ifixit screwdriver wouldn’t work with this as I needed a Phillips with a long skinny shaft.
Philip - Responder
did you find any fuses or motherboard resistors that looked swollen? Mine won’t light up at all
not the plug as I used it to start my other Mondo and the power supply is fine
Murray L. Berkowitz - Responder
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 0
Últimos 7 dias: 1
Últimos 30 dias: 5
Duração total: 699
