O que você precisa
First determine which side of the board has the power button and charging port on it. Then remove the bottom cover of the board by unscrewing the 10 screws on the power button side.
Once you remove the cover unplug the charging port, power button, and LED light to make it easier to work on.
i have change the power port nothing yet the batterie light wont turn red only green ?
Once the cover is completely detached unscrew the nut on the back of the charging port and power button that is securing it in its place. To remove the charging port and power button push them through front of the cover.
Uma outra pessoa concluiu este guia.
