Ir para o conteúdo principal
Google Pixelbook Right Charging Port Replacement
O que você precisa
  1. Google Pixelbook Right Charging Port Replacement, Battery (Back Panel): passo 1, imagem 1 %32 Google Pixelbook Right Charging Port Replacement, Battery (Back Panel): passo 1, imagem 2 %32 Google Pixelbook Right Charging Port Replacement, Battery (Back Panel): passo 1, imagem 3 %32
    • Use the iFixit opening tools or a metal spudger to pry the rubber covers off the back of your Pixelbook.
    • Peel the linings off completely until the back of the Pixelbook looks bare.
  2. Google Pixelbook Right Charging Port Replacement: passo 2, imagem 1 %32 Google Pixelbook Right Charging Port Replacement: passo 2, imagem 2 %32
    • Remove the two yellow 2.0mm screws by using a T3 Torx screwdriver.
  3. Google Pixelbook Right Charging Port Replacement: passo 3, imagem 1 %32 Google Pixelbook Right Charging Port Replacement: passo 3, imagem 2 %32 Google Pixelbook Right Charging Port Replacement: passo 3, imagem 3 %32
    • Remove the seventeen 3.0mm T5 Torx screws from the bottom panel.
  4. Google Pixelbook Right Charging Port Replacement: passo 4, imagem 1 %32 Google Pixelbook Right Charging Port Replacement: passo 4, imagem 2 %32 Google Pixelbook Right Charging Port Replacement: passo 4, imagem 3 %32
    • Use the nylon spudger to pry the edge of the Pixelbook up until you can grab the edge with your fingers.
    • Open the back panel completely and lay it flat so you see the whole inside of the computer.
  5. Google Pixelbook Right Charging Port Replacement: passo 5, imagem 1 %32 Google Pixelbook Right Charging Port Replacement: passo 5, imagem 2 %32
    • Remove the yellow 2.0mm screw from the middle of the panel by using the T3 Torx screwdriver to turn the screw counterclockwise.
  6. Google Pixelbook Right Charging Port Replacement: passo 6, imagem 1 %32 Google Pixelbook Right Charging Port Replacement: passo 6, imagem 2 %32
    • Remove the small, black casing by using the spudger to lift it up from its place.
  7. Google Pixelbook Right Charging Port Replacement: passo 7, imagem 1 %32
    • Disconnect the flat, black cord from the main component by using a spudger to push it out of the slot, or by using your hand to carefully pull it out.
    • Your back panel is now free from the main component.
  8. Google Pixelbook Right Charging Port Replacement, Right Charging Port: passo 8, imagem 1 %32 Google Pixelbook Right Charging Port Replacement, Right Charging Port: passo 8, imagem 2 %32
    • Remove the three 2.0mm black screws from the sound card by using a T5 Torx screwdriver to turn them counterclockwise.
    • Remove the gold 3.0mm screw by using a T3 Torx screwdriver to turn it counterclockwise.
  9. Google Pixelbook Right Charging Port Replacement: passo 9, imagem 1 %32
    • Disconect the thin, black and red cord from the motherboard by using the spudger to snap the connector up and out of place.
  10. Google Pixelbook Right Charging Port Replacement: passo 10, imagem 1 %32
    • Remove the yellow 2.0mm screw by using the T3 Torx screwdriver to turn the screw counterclockwise.
  11. Google Pixelbook Right Charging Port Replacement: passo 11, imagem 1 %32
    • Remove the small, red component by lifting it up with the spudger.
  12. Google Pixelbook Right Charging Port Replacement: passo 12, imagem 1 %32
    • Disconnect the metal component of the thin, black component by lifting it up with the spudger.
  13. Google Pixelbook Right Charging Port Replacement: passo 13, imagem 1 %32 Google Pixelbook Right Charging Port Replacement: passo 13, imagem 2 %32
    Ferramenta utilizada nesse passo:
    Comprar
    • Remove the right charging port by picking it up with the tweezers and lifting it from the computer.
Conclusão
Alon Gary
Membro desde: 01/24/18
550 Reputação
Autoria de 2 guias
Equipe
Cal Poly, Team S18-G1, Livingston Winter 2018 Membro de Cal Poly, Team S18-G1, Livingston Winter 2018
CPSU-LIVINGSTON-W18S18G1
Membros da 4
Autoria de 7 guias
0 comentários
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 1
Últimos 7 dias: 10
Últimos 30 dias: 20
Duração total: 1,598
