Introdução
In this guide, you will learn how to replace the right charging port on your Google Pixelbook Go to fix charging issues.
O que você precisa
Flip the device so that the back is facing up.
Peel the rubber stoppers off the top and bottom of the device.
Remove the three pink screws from the right charging port using a T3 Torx screwdriver.
Quase terminado!
Conclusão
