Ir para o conteúdo principal
Google Pixelbook Go Right Charging Port Replacement
O que você precisa
  1. Google Pixelbook Go Right Charging Port Replacement, Back Panel: passo 1, imagem 1 %32 Google Pixelbook Go Right Charging Port Replacement, Back Panel: passo 1, imagem 2 %32
    • Flip the device so that the back is facing up.
    • Peel the rubber stoppers off the top and bottom of the device.
  2. Google Pixelbook Go Right Charging Port Replacement: passo 2, imagem 1 %32 Google Pixelbook Go Right Charging Port Replacement: passo 2, imagem 2 %32
    • Remove ten 3 mm screws from around the edge of the back panel using a T5 Torx screwdriver.
  3. Google Pixelbook Go Right Charging Port Replacement: passo 3, imagem 1 %32 Google Pixelbook Go Right Charging Port Replacement: passo 3, imagem 2 %32 Google Pixelbook Go Right Charging Port Replacement: passo 3, imagem 3 %32
    • Use an iFixit opening tool to pry up the back panel cover.
    • There is an orange ribbon cable that connects the cover to the base, so don't separate the two pieces completely.
    • Remove the single 2 mm screw using a Torx T3 screwdriver.
    • Disconnect the orange cable from the base of the device.
  4. Google Pixelbook Go Right Charging Port Replacement: passo 4, imagem 1 %32
    • Insert wisdom here.
  5. Google Pixelbook Go Right Charging Port Replacement, Right Charging Port: passo 5, imagem 1 %32
    • Remove the three pink screws from the right charging port using a T3 Torx screwdriver.
  6. Google Pixelbook Go Right Charging Port Replacement: passo 6, imagem 1 %32 Google Pixelbook Go Right Charging Port Replacement: passo 6, imagem 2 %32
    • Remove the right charging port by picking it up and lifting it from the computer.
Conclusão
Katie Brennan
Membro desde: 03/01/23
85 Reputação
Autoria de 1 guia
0 comentários
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 1
Últimos 7 dias: 7
Últimos 30 dias: 13
Duração total: 176
