Ir para o conteúdo principal
Google Pixel Slate Speaker Replacement
O que você precisa
  1. Google Pixel Slate Speaker Replacement, Screen: passo 1, imagem 1 %32 Google Pixel Slate Speaker Replacement, Screen: passo 1, imagem 2 %32 Google Pixel Slate Speaker Replacement, Screen: passo 1, imagem 3 %32
    • Orient the Google Pixel Slate so that the screen is facing upwards.
    • Use the iFixit opening tool to separate screen from main body.
    • Use the suction cup to remove the screen from the body of the device.
  2. Google Pixel Slate Speaker Replacement: passo 2, imagem 1 %32 Google Pixel Slate Speaker Replacement: passo 2, imagem 2 %32 Google Pixel Slate Speaker Replacement: passo 2, imagem 3 %32
    • Gently disconnect the three flat-wires from the screen.
    • Carefully separate and remove the screen from the body of the device.
  3. Google Pixel Slate Speaker Replacement, Speaker: passo 3, imagem 1 %32 Google Pixel Slate Speaker Replacement, Speaker: passo 3, imagem 2 %32 Google Pixel Slate Speaker Replacement, Speaker: passo 3, imagem 3 %32
    • There are two speakers, one on each side of the Google Pixel Slate. This guide works for either one.
    • Use the T2 Torx screwdriver to remove the yellow 2mm screw from the thin metal plate.
    • Use the T3 Torx screwdriver to remove the pink 3mm screw from the thin metal plate.
    • Remove the thin metal plate from the device.
  4. Google Pixel Slate Speaker Replacement: passo 4, imagem 1 %32
    • Use the T2 Torx screwdriver to remove the two black 2mm screws from the speaker.
  5. Google Pixel Slate Speaker Replacement: passo 5, imagem 1 %32 Google Pixel Slate Speaker Replacement: passo 5, imagem 2 %32
    Ferramenta utilizada nesse passo:
    Comprar
    • Use the Nylon-Tipped Tweezers to remove the black plug.
    • There is a red and a black wire connected to the black plug.
    • Pull the black plug in an upwards direction.
    • Be sure to gently remove plug, as using too much force can damage the connecting wires.
  6. Google Pixel Slate Speaker Replacement: passo 6, imagem 1 %32 Google Pixel Slate Speaker Replacement: passo 6, imagem 2 %32
    • Use the Nylon-Tipped Tweezers to disconnect the black tape-like plug connected to the speaker.
  7. Google Pixel Slate Speaker Replacement: passo 7, imagem 1 %32 Google Pixel Slate Speaker Replacement: passo 7, imagem 2 %32
    • Detach the speaker wire from the motherboard.
    • Remove the adhesive strips that hold down the speaker wire.
  8. Google Pixel Slate Speaker Replacement: passo 8, imagem 1 %32 Google Pixel Slate Speaker Replacement: passo 8, imagem 2 %32 Google Pixel Slate Speaker Replacement: passo 8, imagem 3 %32
    • Use the T2 Torx screwdriver to remove the 2mm black screw from the brass plate.
    • Pull back the brass plate.
  9. Google Pixel Slate Speaker Replacement: passo 9, imagem 1 %32
    • You can now remove the speaker from the device.
Conclusão
3 outras pessoas executaram este guia.
Spencer Alonge
Membro desde: 04/18/19
648 Reputação
Autoria de 5 guias
Equipe
Cal Poly, Team S2-G5, Maness Spring 2019 Membro de Cal Poly, Team S2-G5, Maness Spring 2019
CPSU-MANESS-S19S2G5
Membros da 4
Autoria de 5 guias
0 comentários
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 1
Últimos 7 dias: 4
Últimos 30 dias: 15
Duração total: 882
