Ir para o conteúdo principal
Google Pixel Slate Screen Replacement
O que você precisa
  1. Google Pixel Slate Screen Replacement, Screen: passo 1, imagem 1 %32 Google Pixel Slate Screen Replacement, Screen: passo 1, imagem 2 %32 Google Pixel Slate Screen Replacement, Screen: passo 1, imagem 3 %32
    • Orient the Google Pixel Slate so that the screen is facing upwards.
    • Use the iFixit opening tool to separate screen from main body.
    • Use the suction cup to remove the screen from the body of the device.
  2. Google Pixel Slate Screen Replacement: passo 2, imagem 1 %32 Google Pixel Slate Screen Replacement: passo 2, imagem 2 %32 Google Pixel Slate Screen Replacement: passo 2, imagem 3 %32
    • Gently disconnect the three flat-wires from the screen.
    • Carefully separate and remove the screen from the body of the device.
Conclusão
4 outras pessoas executaram este guia.
Spencer Alonge
Membro desde: 04/18/19
648 Reputação
Autoria de 5 guias
Equipe
Cal Poly, Team S2-G5, Maness Spring 2019 Membro de Cal Poly, Team S2-G5, Maness Spring 2019
CPSU-MANESS-S19S2G5
Membros da 4
Autoria de 5 guias
11 comentários
Where did you source the replacement screen? Can we get a link added to the parts list?
Brandon Price - Responder
Anyone know where to source the replacement screen? Any help would be greatly appreciated.
Yeah, I could use the replacement source as well. Thanks.
Benjamin Reese - Responder
me too! the resource replacement link plz!!
gabriela urquidi - Responder
Is the screen held down with adhesive or does it have any clips? Also, does anyone know where I could source any Pixel Slate parts?
Kevin Freyre - Responder
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 2
Últimos 7 dias: 13
Últimos 30 dias: 66
Duração total: 4,554
