Ir para o conteúdo principal
Google Pixel Slate Motherboard Replacement
O que você precisa
  1. Google Pixel Slate Motherboard Replacement, Screen: passo 1, imagem 1 %32 Google Pixel Slate Motherboard Replacement, Screen: passo 1, imagem 2 %32 Google Pixel Slate Motherboard Replacement, Screen: passo 1, imagem 3 %32
    • Orient the Google Pixel Slate so that the screen is facing upwards.
    • Use the iFixit opening tool to separate screen from main body.
    • Use the suction cup to remove the screen from the body of the device.
  2. Google Pixel Slate Motherboard Replacement: passo 2, imagem 1 %32 Google Pixel Slate Motherboard Replacement: passo 2, imagem 2 %32 Google Pixel Slate Motherboard Replacement: passo 2, imagem 3 %32
    • Gently disconnect the three flat-wires from the screen.
    • Carefully separate and remove the screen from the body of the device.
  3. Google Pixel Slate Motherboard Replacement, Motherboard: passo 3, imagem 1 %32 Google Pixel Slate Motherboard Replacement, Motherboard: passo 3, imagem 2 %32 Google Pixel Slate Motherboard Replacement, Motherboard: passo 3, imagem 3 %32
    • Once the screen is removed, remove the two black, adhesive strips.
  4. Google Pixel Slate Motherboard Replacement: passo 4, imagem 1 %32 Google Pixel Slate Motherboard Replacement: passo 4, imagem 2 %32 Google Pixel Slate Motherboard Replacement: passo 4, imagem 3 %32
    • Use a T3 Torx screwdriver to remove the two black screws that are holding down the copper strip.
  5. Google Pixel Slate Motherboard Replacement: passo 5, imagem 1 %32 Google Pixel Slate Motherboard Replacement: passo 5, imagem 2 %32 Google Pixel Slate Motherboard Replacement: passo 5, imagem 3 %32
    • Use the T3 Torx screwdriver to remove the seven 3mm screws.
    • Use a T2 Torx screwdriver to remove the pink 2mm screw closest to the edge.
    • There is a total of four blue 3mm screws, two black 3mm screws, one pink 3mm screw, and one pink 2mm screw holding down the plate.
  6. Google Pixel Slate Motherboard Replacement: passo 6, imagem 1 %32 Google Pixel Slate Motherboard Replacement: passo 6, imagem 2 %32
    • Lift and remove the metal plate.
  7. Google Pixel Slate Motherboard Replacement: passo 7, imagem 1 %32 Google Pixel Slate Motherboard Replacement: passo 7, imagem 2 %32 Google Pixel Slate Motherboard Replacement: passo 7, imagem 3 %32
    Ferramenta utilizada nesse passo:
    Comprar
    • Remove the two speaker plugs, one battery plug, and disconnect the four flat wires from the motherboard.
    • Nylon Tipped Tweezers may be necessary to remove the wires effectively.
  8. Google Pixel Slate Motherboard Replacement: passo 8, imagem 1 %32 Google Pixel Slate Motherboard Replacement: passo 8, imagem 2 %32 Google Pixel Slate Motherboard Replacement: passo 8, imagem 3 %32
    • Use a T3 Torx screwdriver to remove the two silver screws.
    • Remove the 4 exposed washers from the motherboard and put aside.
  9. Google Pixel Slate Motherboard Replacement: passo 9, imagem 1 %32 Google Pixel Slate Motherboard Replacement: passo 9, imagem 2 %32 Google Pixel Slate Motherboard Replacement: passo 9, imagem 3 %32
    • Use the iFixit opening tool to remove the motherboard from the device.
Conclusão
3 outras pessoas executaram este guia.
Spencer Alonge
Membro desde: 04/18/19
648 Reputação
Autoria de 5 guias
Equipe
Cal Poly, Team S2-G5, Maness Spring 2019 Membro de Cal Poly, Team S2-G5, Maness Spring 2019
CPSU-MANESS-S19S2G5
Membros da 4
Autoria de 5 guias
Um comentário
Very helpful, nice and clear steps.
Eddie Lundberg - Responder
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 7
Últimos 7 dias: 20
Últimos 30 dias: 65
Duração total: 3,257
