Ir para o conteúdo principal
Google Pixel Slate Front-Facing Camera Replacement
O que você precisa
  1. Google Pixel Slate Front-Facing Camera Replacement, Screen: passo 1, imagem 1 %32 Google Pixel Slate Front-Facing Camera Replacement, Screen: passo 1, imagem 2 %32 Google Pixel Slate Front-Facing Camera Replacement, Screen: passo 1, imagem 3 %32
    • Orient the Google Pixel Slate so that the screen is facing upwards.
    • Use the iFixit opening tool to separate screen from main body.
    • Use the suction cup to remove the screen from the body of the device.
  2. Google Pixel Slate Front-Facing Camera Replacement: passo 2, imagem 1 %32 Google Pixel Slate Front-Facing Camera Replacement: passo 2, imagem 2 %32 Google Pixel Slate Front-Facing Camera Replacement: passo 2, imagem 3 %32
    • Gently disconnect the three flat-wires from the screen.
    • Carefully separate and remove the screen from the body of the device.
  3. Google Pixel Slate Front-Facing Camera Replacement, Front-Facing Camera: passo 3, imagem 1 %32 Google Pixel Slate Front-Facing Camera Replacement, Front-Facing Camera: passo 3, imagem 2 %32 Google Pixel Slate Front-Facing Camera Replacement, Front-Facing Camera: passo 3, imagem 3 %32
    • Once removed, place the screen face down.
    • Peel back the black, adhesive strip covering the front camera so that the silver plate is exposed.
  4. Google Pixel Slate Front-Facing Camera Replacement: passo 4, imagem 1 %32 Google Pixel Slate Front-Facing Camera Replacement: passo 4, imagem 2 %32 Google Pixel Slate Front-Facing Camera Replacement: passo 4, imagem 3 %32
    • Hold back the adhesive tape to expose the two black 2mm screws that are holding down the cover plate.
    • Use the T2 Torx screwdriver to remove the two 2mm screws.
  5. Google Pixel Slate Front-Facing Camera Replacement: passo 5, imagem 1 %32 Google Pixel Slate Front-Facing Camera Replacement: passo 5, imagem 2 %32
    • Once the two 2mm screws are removed, lift and remove the cover plate.
  6. Google Pixel Slate Front-Facing Camera Replacement: passo 6, imagem 1 %32 Google Pixel Slate Front-Facing Camera Replacement: passo 6, imagem 2 %32
    • Pull upwards on the flat wire to remove the front-facing camera from the device.
    • The camera may be secured to the screen body with adhesive tape. Apply gentle force to remove the camera by removing the tape.
Conclusão
Spencer Alonge
Membro desde: 04/18/19
648 Reputação
Autoria de 5 guias
Equipe
Cal Poly, Team S2-G5, Maness Spring 2019 Membro de Cal Poly, Team S2-G5, Maness Spring 2019
CPSU-MANESS-S19S2G5
Membros da 4
Autoria de 5 guias
0 comentários
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 4
Últimos 7 dias: 6
Últimos 30 dias: 15
Duração total: 802
