Ir para o conteúdo principal
Conserte seus objetos
Direito de executar reparos
Loja
Introdução
Follow this guide to replace a broken or cracked screen on a Pixel 4a.
The Pixel 4a’s unreinforced display panel is fragile. Pay special attention to the warnings in the opening procedure if you are reusing the screen.
  1. You will need to pry the screen up to remove it from the phone. Read the following notes carefully before proceeding. Take note of the two seams on the edge of the phone: Screen seam: This seam separates the screen from the rest of the phone. This is where you should pry.
    • You will need to pry the screen up to remove it from the phone. Read the following notes carefully before proceeding.
    • Take note of the two seams on the edge of the phone:
    • Screen seam: This seam separates the screen from the rest of the phone. This is where you should pry.
    • Frame seam: This is where the plastic frame meets the back cover. It is held in place by screws. Do not pry at this seam.
    • Before you begin, note the following areas on the screen:
    • Screen flex cable: Do not insert the opening pick deeper than instructed or you risk damaging this cable.
    • Adhesive perimeter: Prying beyond this narrow perimeter without angling the pick will damage the OLED panel.
  2. Apply a heated iOpener to the right edge of the display for one minute to soften the adhesive.
    • Apply a heated iOpener to the right edge of the display for one minute to soften the adhesive.
    • A hair dryer, heat gun, or hot plate may also be used, but be careful not to overheat the phone—the display and internal battery are both susceptible to heat damage.
  3. If your display is badly cracked, covering it with a layer of clear packing tape may allow the suction cup to adhere. Alternatively, very strong tape may be used instead of the suction cup. If all else fails, you can superglue the suction cup to the broken screen. Place a suction cup as close to the right edge of the screen as possible. Lift the suction cup with a strong steady force.
    • If your display is badly cracked, covering it with a layer of clear packing tape may allow the suction cup to adhere. Alternatively, very strong tape may be used instead of the suction cup. If all else fails, you can superglue the suction cup to the broken screen.
    • Place a suction cup as close to the right edge of the screen as possible.
    • Lift the suction cup with a strong steady force.
    • Insert the tip of an opening pick into the screen seam no more than 1 mm.
  4. This step shows how to insert the pick without damaging the OLED panel. Do this before beginning to slice the adhesive. With the pick 1 mm into the gap, pivot the pick upwards to a steep angle. At a steep angle, carefully push the pick into the gap about 1/4 inch (6 mm). The pick should slide in below the OLED panel.
    • This step shows how to insert the pick without damaging the OLED panel. Do this before beginning to slice the adhesive.
    • With the pick 1 mm into the gap, pivot the pick upwards to a steep angle.
    • At a steep angle, carefully push the pick into the gap about 1/4 inch (6 mm). The pick should slide in below the OLED panel.
    • Stop if you feel the point of the pick hitting a ridge. The pick may be pressing against the edge of the OLED panel. Angle the pick and try again.
  5. Slide the pick along the right edge of the screen to cut the adhesive. Do not insert the pick more than 1/4 inch (6 mm) or you may damage the screen's flex cable. Leave the pick in the top right corner to prevent the adhesive from re-sealing.
    • Slide the pick along the right edge of the screen to cut the adhesive.
    • Do not insert the pick more than 1/4 inch (6 mm) or you may damage the screen's flex cable.
    • Leave the pick in the top right corner to prevent the adhesive from re-sealing.
  6. The screen adhesive is very weak and you should not need to re-apply heat. If the screen does feel hard to slice, apply heat to the difficult area for one minute and try again. Insert another opening pick into the right  edge of the phone at an angle where a gap has already formed to prevent damage to the OLED panel. Slide the opening pick around the bottom of the phone to cut the adhesive.
    • The screen adhesive is very weak and you should not need to re-apply heat. If the screen does feel hard to slice, apply heat to the difficult area for one minute and try again.
    • Insert another opening pick into the right edge of the phone at an angle where a gap has already formed to prevent damage to the OLED panel.
    • Slide the opening pick around the bottom of the phone to cut the adhesive.
    • Leave the pick inserted along the bottom edge to prevent the adhesive from resealing.
  7. Insert another opening pick into the bottom edge of the phone at an angle where a gap has already formed to prevent damage to the OLED panel. Use the pick to slice through the left edge of the phone. If the screen feels hard to slice, heat the left edge for one minute and try again.
    • Insert another opening pick into the bottom edge of the phone at an angle where a gap has already formed to prevent damage to the OLED panel.
    • Use the pick to slice through the left edge of the phone.
    • If the screen feels hard to slice, heat the left edge for one minute and try again.
    • Leave the pick inserted along the left edge of the phone to prevent the adhesive from re-sealing.
  8. Insert another opening pick into the left edge of the phone at an angle where a gap has already formed to prevent damage to the OLED panel. Slide the pick around the top edge of the phone to cut the adhesive. If the screen feels hard to slice, heat the top edge for one minute and try again.
    • Insert another opening pick into the left edge of the phone at an angle where a gap has already formed to prevent damage to the OLED panel.
    • Slide the pick around the top edge of the phone to cut the adhesive.
    • If the screen feels hard to slice, heat the top edge for one minute and try again.
  9. Once you have cut around the perimeter of the phone, carefully lift the right edge of the screen, opening the phone like a book. Do not remove the screen yet.
    • Once you have cut around the perimeter of the phone, carefully lift the right edge of the screen, opening the phone like a book.
    • Do not remove the screen yet.
    • Use an opening pick to carefully cut through any remaining adhesive.
  10. Lift from the top edge and swing the screen over the bottom edge until you can rest it glass-side down. Be careful not to put any stress on the attached ribbon cable. Be careful not to put any stress on the attached ribbon cable.
    • Lift from the top edge and swing the screen over the bottom edge until you can rest it glass-side down.
    • Be careful not to put any stress on the attached ribbon cable.
  11. Use a pair of tweezers to carefully peel up the black tape covering the screen connector bracket.
    • Use a pair of tweezers to carefully peel up the black tape covering the screen connector bracket.
    • If it is in good condition, you can re-use this tape during reassembly. Otherwise, replace it with a piece of electrical tape.
  12. Use a T3 Torx driver to remove the two 2.1 mm screws securing the screen connector bracket.
    • Use a T3 Torx driver to remove the two 2.1 mm screws securing the screen connector bracket.
  13. Use a pair of tweezers to remove the screen connector bracket.
    • Use a pair of tweezers to remove the screen connector bracket.
  14. Use the tip of a spudger to pry up and disconnect the screen flex cable. To re-attach press connectors like this one, carefully align and press down on one side until it clicks into place, then repeat on the other side. Do not press down on the middle. If the connector is misaligned, the pins can bend, causing permanent damage.
    • Use the tip of a spudger to pry up and disconnect the screen flex cable.
    • To re-attach press connectors like this one, carefully align and press down on one side until it clicks into place, then repeat on the other side. Do not press down on the middle. If the connector is misaligned, the pins can bend, causing permanent damage.
  15. Remove the screen.
    • Remove the screen.
    • Compare your replacement screen with the original. You may need to transfer additional components (such as speaker mesh) to the new part.
    • To install the new screen:
    • Scrape off remaining adhesive from the perimeter of the frame.
    • Follow this guide if you are using custom-cut adhesives.
    • If you are using double-sided tape such as Tesa tape, follow this guide.
Conclusão
7 outras pessoas concluíram este guia.
Sam Omiotek
Membro desde: 25/02/2019
19.236 Reputação
136 Guias de autoria
Equipe
iFixit Membro de iFixit
Community
134 Membros
15.523 Guias de autoria
Really nice repair guide. But no place to buy the screen.
jeffreyjantos - Responder
Yep, still waiting for it to be available.
Paul -
Same, still waiting. I have a broken pixel 4a and I have a right to repair it.
Erik Fry -
Here is one.
VauWeh -
Where do you recommend that I purchase the Pixel4a screen replacement from? I found these two with Witrigs being cheaper, but not sure if either are reliable high quality screens.
https://www.witrigs.com/oem-screen-repla...
https://phoneremedies.com/collections/go...
Alejandro Gaytan - Responder
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 90
Últimos 7 dias: 635
Últimos 30 dias: 2,694
Duração total: 11,638
