Esta versão pode conter edições incorretas. Mude para o último instantâneo verificado.
O que você precisa
Este passo não foi traduzido. Ajude a traduzi-lo
Heat an iOpener and apply it to the bottom of the phone for one minute.
Apply a suction cup to the heated bottom edge of the back cover.
Lift on the suction cup with strong, steady force to create a gap.
Insert an opening pick into the gap.
Slice the adhesive along the bottom edge of the phone and around the right corner.
Leave a pick in the bottom edge to prevent the adhesive from re-sealing.
Heat the right edge with an iOpener and continue slicing the adhesive with an opening pick.
Continue heating and slicing through the rest of the phone perimeter. Leave a pick in each edge to prevent the adhesive from resealing.
Once you have sliced around the perimeter of the phone, carefully lift the left edge of the back cover.
Flip the back cover along its long axis and rest it so that the fingerprint sensor cable is not strained.
Ferramenta utilizada nesse passo:Magnetic Project Mat$19.95-
Remove the two 4.1 mm-long Phillips screws securing the fingerprint connector bracket.
Use the point of a spudger to slide the fingerprint connector bracket out from under the NFC coil.
Remove the fingerprint connector bracket.
Use the point of a spudger to pry up and disconnect the fingerprint connector from its socket.
27 outras pessoas executaram este guia.
12 comentários
My back cover would not come off by just using an iOpener. After getting a heat gun and applying the heat to the bottom corners I was able to get the adhesive weak enough to pry open.
Where can I buy all the tools needed to repair my Pixel 3?
How do you ensure the back cover is waterproof after putting it on? The precut adhesive card turns out just to be a roll of tesa tape, it would be nice if it actually had round cutouts, or large rectangular sections to custom cut to ensure water proofing around fingerprint sensor, and camera flash led.
Hi Daniel,
Unfortunately, there is no easy way to ensure water resistance after a repair, as the factory adhesive is applied using specialty tools. I’d suggest sealing it the best you can with adhesive and using a water resistant case.
On the adhesive product page, you can find the adhesive card under the first pull-down menu. The adhesive card does have rounded corners and cutouts for this purpose.
