Ir para o conteúdo principal
Google Pixel 2 Midframe Replacement
Pré-requisito somente
Este guia destina-se apenas a ser usado como pré-requisito para outros guias. É incompleto por si só.
O que você precisa
  1. Google Pixel 2 Midframe Replacement, Midframe: passo 1, imagem 1 %32
    • Apply a heated iOpener to the proximity sensor on the top edge of the midframe for two minutes to soften its adhesive.
  2. Google Pixel 2 Midframe Replacement: passo 2, imagem 1 %32 Google Pixel 2 Midframe Replacement: passo 2, imagem 2 %32
    • Slide the point of a spudger under the proximity sensor cable, starting from the side closest to the front-facing camera.
    • Gently lift the edge of the sensor cable until the sensor is perpendicular to the midframe.
  3. Google Pixel 2 Midframe Replacement: passo 3, imagem 1 %32
    Ferramenta utilizada nesse passo:
    Magnetic Project Mat
    $19.95
    Comprar
    • Peel back the small piece of tape covering the screw below the earpiece speaker. Peel back any tape covering other screws as well.
    • Remove the following screws securing the midframe:
    • Eleven 3.7 mm Phillips screws
    • One 4 mm T5 Torx screw
  4. Google Pixel 2 Midframe Replacement: passo 4, imagem 1 %32 Google Pixel 2 Midframe Replacement: passo 4, imagem 2 %32
    • Insert an opening tool into the notch in the midframe near the hold button.
    • Pry the midframe up enough to create a gap between it and the phone case. The midframe cannot yet be completely removed.
  5. Google Pixel 2 Midframe Replacement: passo 5, imagem 1 %32 Google Pixel 2 Midframe Replacement: passo 5, imagem 2 %32 Google Pixel 2 Midframe Replacement: passo 5, imagem 3 %32
    • Lift the midframe up starting from the bottom edge.
    • When the midframe starts to make about a 45° with the rest of the phone, lift the midframe straight up and away from the phone.
    • As you lift the midfame, carefully guide the proximity sensor through the small slot in the midframe.
Conclusão
Adam O'Camb
Membro desde: 04/11/15
196.194 Reputação
Autoria de 416 guias
0 comentários
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 0
Últimos 7 dias: 0
Últimos 30 dias: 1
Duração total: 85
