Introdução
This guide will teach you how to replace a faulty mute button switch in your Google Home with a new one.
O que você precisa
Pull off the Google Home’s magnetically attached base and set it aside.
Using a Torx T6 screwdriver head, unscrew the four 1.7mm Torx screws deep in the speaker recess so that you can remove the lid.
After all four screws are out, pop the lid off the device to open the capsule.
Remove the ‘O-ring’ that wraps around the device holding the switch panel in place.
Uma outra pessoa concluiu este guia.
