Ir para o conteúdo principal
Google Home Motherboard Replacement
O que você precisa
  1. Google Home Motherboard Replacement, Interconnect Cable: passo 1, imagem 1 %32 Google Home Motherboard Replacement, Interconnect Cable: passo 1, imagem 2 %32 Google Home Motherboard Replacement, Interconnect Cable: passo 1, imagem 3 %32
    • Removing the lid too quickly could cause you to tear the interconnect cable that attaches the base to the top of the lid.
    • Pull off the Google Home’s magnetically attached base and set it aside.
    • Using a Torx T6 screwdriver head, unscrew the four 1.7mm Torx screws deep in the speaker recess so that you can remove the lid.
    • After all four screws are out, pop the lid off the device to open the capsule.
  2. Google Home Motherboard Replacement: passo 2, imagem 1 %32
    • Carefully remove the interconnect cable using a pair of tweezers.
  3. Google Home Motherboard Replacement, Mute Button Switch: passo 3, imagem 1 %32 Google Home Motherboard Replacement, Mute Button Switch: passo 3, imagem 2 %32
    • Remove the ‘O-ring’ that wraps around the device holding the switch panel in place.
  4. Google Home Motherboard Replacement: passo 4, imagem 1 %32 Google Home Motherboard Replacement: passo 4, imagem 2 %32
    • Using a Torx T6 screwdriver head, unscrew the four black 1.7mm Torx screws.
    • Remove the panel and the mute button switch. If done correctly you should now be able to see the device’s guitar-shaped motherboard.
  5. Google Home Motherboard Replacement, Motherboard: passo 5, imagem 1 %32 Google Home Motherboard Replacement, Motherboard: passo 5, imagem 2 %32
    • Disconnect the foam-padded, red and black cable that connects the motherboard to the sound driver, by squeezing and pulling on the tab
    • Disconnect the orange interconnect cable that connects the bottom of the device to the motherboard by pulling straight out on the orange tab.
  6. Google Home Motherboard Replacement: passo 6, imagem 1 %32 Google Home Motherboard Replacement: passo 6, imagem 2 %32
    • Using a Torx T6 screwdriver head, unscrew the five silver 1.7mm Torx screws keeping the motherboard in place.
    • Remove the motherboard.
Conclusão
3 outras pessoas executaram este guia.
Maya Wharton
Membro desde: 04/17/18
175 Reputação
Autoria de 1 guia
Equipe
Cal Poly, Team S24-G11, Maness Spring 2018 Membro de Cal Poly, Team S24-G11, Maness Spring 2018
CPSU-MANESS-S18S24G11
Membros da 4
Autoria de 5 guias
2 comentários
Where can one purchase a replacement motherboard?
Jim Pflasterer - Responder
Most likely the only place to do so would be through contacting Google, as there is no parts sold at retail, only full units
Nick Bergstrom -
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 0
Últimos 7 dias: 3
Últimos 30 dias: 20
Duração total: 3,152
