Introdução
A guide to change Google Home Mini USB power port.
O que você precisa
Remove the rubber bottom as per the Google Home Mini teardown guide.
Remove the four 7mm T6 Torx screws from the bottom.
Using a pair of tweezers, unlatch the Zero Insertion Force (ZIF) fastener that connects the ribbon cable to the board.
What if this breaks off. Can i direct connect power.
Where to buy it please tell please
9 outras pessoas executaram este guia.
8 comentários
Where I can buy micro USB PCB ?
Would like to know this as well disapointing to have an instruction on how to replace a part, but nowere to buy it.
Has anyone had any luck buying a replacement part?
If you're able to solder, you can find micro USB ports on Digi-Key.
Forgot to confirm the pin count while mine was taken apart, but would bet it's similar to many common ports such as PN: 10118194-0001LF
Somebody know where to buy it?
