Ir para o conteúdo principal
Google Home Mini USB Power Port Replacement
O que você precisa
  1. Google Home Mini USB Power Port Replacement, Google Home Mini Disassembly: passo 1, imagem 1 %32
    • Place device on a flat surface.
  2. Google Home Mini USB Power Port Replacement: passo 2, imagem 1 %32
  3. Google Home Mini USB Power Port Replacement: passo 3, imagem 1 %32
    • Remove the lower half of the device.
    • Be careful as a black ribbon cable connects the two halves together.
  4. Google Home Mini USB Power Port Replacement: passo 4, imagem 1 %32
    Ferramenta utilizada nesse passo:
    Comprar
    • Using a pair of tweezers, unlatch the Zero Insertion Force (ZIF) fastener that connects the ribbon cable to the board.
    • Flip up and push the ZIF fastener towards outside of the lower case to loosen it.
  5. Google Home Mini USB Power Port Replacement: passo 5, imagem 1 %32
    • Pull the ribbon cable off.
  6. Google Home Mini USB Power Port Replacement, USB Power Port: passo 6, imagem 1 %32 Google Home Mini USB Power Port Replacement, USB Power Port: passo 6, imagem 2 %32
    • Remove the three 5.3mm T6 Torx screws from the board.
  7. Google Home Mini USB Power Port Replacement: passo 7, imagem 1 %32 Google Home Mini USB Power Port Replacement: passo 7, imagem 2 %32
    • Remove the black metal plate from the board.
  8. Google Home Mini USB Power Port Replacement: passo 8, imagem 1 %32 Google Home Mini USB Power Port Replacement: passo 8, imagem 2 %32
    • Remove the board.
Conclusão
9 outras pessoas executaram este guia.
Mia Sulaiman
Membro desde: 05/21/18
1.032 Reputação
Autoria de 3 guias
Equipe
IUPUI, Team S1-G4, Harley Spring 2018 Membro de IUPUI, Team S1-G4, Harley Spring 2018
IUPUI-HARLEY-S18S1G4
Membros da 7
Autoria de 5 guias
8 comentários
Where I can buy micro USB PCB ?
so_ang - Responder
Planet Carl - Responder
Would like to know this as well disapointing to have an instruction on how to replace a part, but nowere to buy it.
Wolve 8383 - Responder
Has anyone had any luck buying a replacement part?
Caitlin Barnum - Responder
Just broke mine :-(
Is anyone managed to find a place to buy one?
Jim - Responder
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 2
Últimos 7 dias: 17
Últimos 30 dias: 63
Duração total: 6,159
