Ir para o conteúdo principal
Google Home Mini Speaker Replacement
O que você precisa
  1. Google Home Mini Speaker Replacement, Google Home Mini Disassembly: passo 1, imagem 1 %32
    • Place device on a flat surface.
  2. Google Home Mini Speaker Replacement: passo 2, imagem 1 %32
  3. Google Home Mini Speaker Replacement: passo 3, imagem 1 %32
    • Remove the lower half of the device.
    • Be careful as a black ribbon cable connects the two halves together.
  4. Google Home Mini Speaker Replacement: passo 4, imagem 1 %32
    • Using a pair of tweezers, unlatch the Zero Insertion Force (ZIF) fastener that connects the ribbon cable to the board.
    • Flip up and push the ZIF fastener towards outside of the lower case to loosen it.
  5. Google Home Mini Speaker Replacement: passo 5, imagem 1 %32
    • Pull the ribbon cable off.
  6. Google Home Mini Speaker Replacement, Speaker: passo 6, imagem 1 %32
    • Remove the four 7.8mm T8 Torx screws.
  7. Google Home Mini Speaker Replacement: passo 7, imagem 1 %32 Google Home Mini Speaker Replacement: passo 7, imagem 2 %32 Google Home Mini Speaker Replacement: passo 7, imagem 3 %32
    • The speaker will still be connected to the device.
    • Using your fingers, disconnect the wires.
Conclusão
8 outras pessoas executaram este guia.
Mia Sulaiman
Membro desde: 05/21/18
1.032 Reputação
Autoria de 3 guias
Equipe
IUPUI, Team S1-G4, Harley Spring 2018 Membro de IUPUI, Team S1-G4, Harley Spring 2018
IUPUI-HARLEY-S18S1G4
Membros da 7
Autoria de 5 guias
2 comentários
HI There I only have 2 lights on the google mini - and although it was working yesterday - with all 4 lights - it most certainly isn't now? I am not sure why and I am not sure what has happened?
susan woods - Responder
Okay, but where can one obtain a spare speaker?
Bil McArthur - Responder
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 2
Últimos 7 dias: 23
Últimos 30 dias: 84
Duração total: 7,016
