Introdução
A guide to disassemble Google Home Mini for further repairs.
O que você precisa
Remove the rubber bottom as per the Google Home Mini teardown guide.
Remove the four 7mm T6 Torx screws from the bottom.
Using a pair of tweezers, unlatch the Zero Insertion Force (ZIF) fastener that connects the ribbon cable to the board.
What if this breaks off. Can i direct connect power.
Where to buy it please tell please
12 outras pessoas executaram este guia.
2 comentários
How did you get the rubber base off of it?
There’s a little more explanation here
