Ir para o conteúdo principal
Google Home LED Board Replacement
O que você precisa
  1. Google Home LED Board Replacement, Interconnect Cable: passo 1, imagem 1 %32 Google Home LED Board Replacement, Interconnect Cable: passo 1, imagem 2 %32 Google Home LED Board Replacement, Interconnect Cable: passo 1, imagem 3 %32
    • Removing the lid too quickly could cause you to tear the interconnect cable that attaches the base to the top of the lid.
    • Pull off the Google Home’s magnetically attached base and set it aside.
    • Using a Torx T6 screwdriver head, unscrew the four 1.7mm Torx screws deep in the speaker recess so that you can remove the lid.
    • After all four screws are out, pop the lid off the device to open the capsule.
  2. Google Home LED Board Replacement: passo 2, imagem 1 %32
    Ferramenta utilizada nesse passo:
    Comprar
    • Carefully remove the interconnect cable using a pair of tweezers.
  3. Google Home LED Board Replacement, LED Board: passo 3, imagem 1 %32 Google Home LED Board Replacement, LED Board: passo 3, imagem 2 %32
    • Use a metal spudger to pry the LED board away from the lid.
    • This will require some force because there is a strong adhesive layer that keeps the LED board attached to the lid, so don’t worry about being gentle.
    • Remove the LED board.
Conclusão
Gabe Hyun
Membro desde: 04/17/18
826 Reputação
Autoria de 4 guias
Equipe
Cal Poly, Team S24-G11, Maness Spring 2018 Membro de Cal Poly, Team S24-G11, Maness Spring 2018
CPSU-MANESS-S18S24G11
Membros da 4
Autoria de 5 guias
0 comentários
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 0
Últimos 7 dias: 8
Últimos 30 dias: 18
Duração total: 730
