Ir para o conteúdo principal
Google Cr-48 Chromebook RAM Replacement
O que você precisa
  1. Google Cr-48 Chromebook RAM Replacement, Battery: passo 1, imagem 1 %32 Google Cr-48 Chromebook RAM Replacement, Battery: passo 1, imagem 2 %32 Google Cr-48 Chromebook RAM Replacement, Battery: passo 1, imagem 3 %32
    • Slide the switch on the bottom of the laptop until the battery pops out.
    • Once the battery pops out, you can remove it.
  2. Google Cr-48 Chromebook RAM Replacement, Remove Rear Rubber Feet: passo 2, imagem 1 %32 Google Cr-48 Chromebook RAM Replacement, Remove Rear Rubber Feet: passo 2, imagem 2 %32
    Ferramenta utilizada nesse passo:
    Comprar
    • Using a pair of tweezers, remove the two rear rubber feet to expose two hidden screws.
  3. Google Cr-48 Chromebook RAM Replacement, Remove Screws: passo 3, imagem 1 %32 Google Cr-48 Chromebook RAM Replacement, Remove Screws: passo 3, imagem 2 %32 Google Cr-48 Chromebook RAM Replacement, Remove Screws: passo 3, imagem 3 %32
    • Remove ten 3 mm screws in the battery compartment using a Phillips #00 screwdriver.
    • Remove two 4.5 mm screws under the rubber feet using a Phillips #00 screwdriver.
  4. Google Cr-48 Chromebook RAM Replacement: passo 4, imagem 1 %32 Google Cr-48 Chromebook RAM Replacement: passo 4, imagem 2 %32 Google Cr-48 Chromebook RAM Replacement: passo 4, imagem 3 %32
    • Starting where the body of the laptop and the laptop screen meet, pry apart the lower case from the rest of the laptop.
    • The case is easier to remove when separating in a clockwise motion, as seen in the pictures.
  5. Google Cr-48 Chromebook RAM Replacement, RAM: passo 5, imagem 1 %32 Google Cr-48 Chromebook RAM Replacement, RAM: passo 5, imagem 2 %32 Google Cr-48 Chromebook RAM Replacement, RAM: passo 5, imagem 3 %32
    • Locate the RAM under a black flap alongside where the laptop screen and device body meet.
  6. Google Cr-48 Chromebook RAM Replacement: passo 6, imagem 1 %32 Google Cr-48 Chromebook RAM Replacement: passo 6, imagem 2 %32 Google Cr-48 Chromebook RAM Replacement: passo 6, imagem 3 %32
    • Using your thumbs, pull the metal arms away from the RAM and then the RAM card should pop up.
  7. Google Cr-48 Chromebook RAM Replacement: passo 7, imagem 1 %32 Google Cr-48 Chromebook RAM Replacement: passo 7, imagem 2 %32
    • Use two fingers to slide the RAM out at the angle that it has been released.
    • Be careful when removing or replacing the RAM sticks that you don't bend the pins or they won't attach properly to the socket.
Conclusão
Athar
Membro desde: 09/09/14
365 Reputação
Autoria de 2 guias
Equipe
CSU Fullerton, Team 2-2, Bruce Fall 2014 Membro de CSU Fullerton, Team 2-2, Bruce Fall 2014
CSUF-BRUCE-F14S2G2
Membros da 3
Autoria de 10 guias
0 comentários
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 2
Últimos 7 dias: 3
Últimos 30 dias: 16
Duração total: 1,985
