Ir para o conteúdo principal
Google Chromebook Pixel 2 Fan Replacement
O que você precisa
  1. Google Chromebook Pixel 2 Fan Replacement, Back Panel: passo 1, imagem 1 %32
    • Working on your device while it is turned on may result in electric shock. Make sure to shut down and unplug your device before you begin.
    • Flip your device over so the bottom panel is facing up.
  2. Google Chromebook Pixel 2 Fan Replacement: passo 2, imagem 1 %32
    • Peel off the black rubber strips from top and bottom of the back panel.
  3. Google Chromebook Pixel 2 Fan Replacement: passo 3, imagem 1 %32 Google Chromebook Pixel 2 Fan Replacement: passo 3, imagem 2 %32
    • Remove the fifteen 3 mm Phillips #00 screws from the back panel.
  4. Google Chromebook Pixel 2 Fan Replacement: passo 4, imagem 1 %32
    • Carefully lift the back panel off of the device.
  5. Google Chromebook Pixel 2 Fan Replacement, Fan: passo 5, imagem 1 %32 Google Chromebook Pixel 2 Fan Replacement, Fan: passo 5, imagem 2 %32
    • Remove the three blue 4.0 mm Phillips #00 screws from the fan on the right side.
  6. Google Chromebook Pixel 2 Fan Replacement: passo 6, imagem 1 %32
    • Using the plastic opening tool, slide out the right fan’s connector out of the motherboard slot.
  7. Google Chromebook Pixel 2 Fan Replacement: passo 7, imagem 1 %32
    • Carefully remove lift the right fan out of its slot.
  8. Google Chromebook Pixel 2 Fan Replacement: passo 8, imagem 1 %32 Google Chromebook Pixel 2 Fan Replacement: passo 8, imagem 2 %32
    • Remove three blue 4.0 mm Phillips #00 screws from the left fan.
  9. Google Chromebook Pixel 2 Fan Replacement: passo 9, imagem 1 %32
    • Using the plastic opening tool, slide out the left fan’s connector.
  10. Google Chromebook Pixel 2 Fan Replacement: passo 10, imagem 1 %32
    • Gently lift the left fan out of its slot.
Conclusão
Uma outra pessoa concluiu este guia.
Garrett Monteiro
Membro desde: 04/26/17
413 Reputação
Autoria de 3 guias
Equipe
Cal Poly, Team S22-G6, Livingston Spring 2017 Membro de Cal Poly, Team S22-G6, Livingston Spring 2017
CPSU-LIVINGSTON-S17S22G6
Membros da 4
Autoria de 3 guias
0 comentários
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 0
Últimos 7 dias: 3
Últimos 30 dias: 3
Duração total: 144
