Ir para o conteúdo principal
Goodman GSX16 Central Air Conditioning Unit Filter Replacement
  1. Goodman GSX16 Central Air Conditioning Unit Filter Replacement, Filter: passo 1, imagem 1 %32
    • Turn the air conditioner unit off prior to changing the air filter.
  2. Goodman GSX16 Central Air Conditioning Unit Filter Replacement: passo 2, imagem 1 %32
    • Go into the attic where your air conditioner unit is located via the access door on the ceiling or wherever your air conditioner is located.
  3. Goodman GSX16 Central Air Conditioning Unit Filter Replacement: passo 3, imagem 1 %32 Goodman GSX16 Central Air Conditioning Unit Filter Replacement: passo 3, imagem 2 %32 Goodman GSX16 Central Air Conditioning Unit Filter Replacement: passo 3, imagem 3 %32
    • Open the filter access door and pull the old filter out.
  4. Goodman GSX16 Central Air Conditioning Unit Filter Replacement: passo 4, imagem 1 %32
    • Place the new filter in the unit with the arrow pointing towards the air conditioner unit.
  5. Goodman GSX16 Central Air Conditioning Unit Filter Replacement: passo 5, imagem 1 %32
    • Close the door to the filter and make sure it is snug with no air leakage.
  6. Goodman GSX16 Central Air Conditioning Unit Filter Replacement: passo 6, imagem 1 %32
    • Turn the air conditioner unit back on.
Conclusão
Janice Farris
Membro desde: 10/08/20
141 Reputação
Autoria de 1 guia
0 comentários
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 3
Últimos 7 dias: 26
Últimos 30 dias: 96
Duração total: 2,078
