Ir para o conteúdo principal
Golf Club Shaft Replacement
O que você precisa
  1. Golf Club Shaft Replacement, Shaft: passo 1, imagem 1 %32
    • Use a heat gun to melt the old epoxy holding the club head to the old shaft.
    • Caution: Heat guns can get very hot, so use caution when handling them.
  2. Golf Club Shaft Replacement: passo 2, imagem 1 %32 Golf Club Shaft Replacement: passo 2, imagem 2 %32 Golf Club Shaft Replacement: passo 2, imagem 3 %32
    • Stabilize the club shaft using a vise grip or the weight of a friend.
    • With a pair of oven mitts, remove the club head by carefully twisting it from the shaft.
  3. Golf Club Shaft Replacement: passo 3, imagem 1 %32 Golf Club Shaft Replacement: passo 3, imagem 2 %32
    • Clean out the inside of the club head with acetone and a small wire brush.
    • Cleaning the club head will make applying the new epoxy effective.
  4. Golf Club Shaft Replacement: passo 4, imagem 1 %32
    • Place the cleaned club head on the new shaft and mark the where the end of the club head reaches on the shaft.
    • Remove the club head.
  5. Golf Club Shaft Replacement: passo 5, imagem 1 %32 Golf Club Shaft Replacement: passo 5, imagem 2 %32 Golf Club Shaft Replacement: passo 5, imagem 3 %32
    • Take some sand paper and sand the shaft past your mark leading to the tip.
    • A good technique is to wrap the sandpaper around the tip while twisting the hand holding the sandpaper back and forth.
  6. Golf Club Shaft Replacement: passo 6, imagem 1 %32 Golf Club Shaft Replacement: passo 6, imagem 2 %32 Golf Club Shaft Replacement: passo 6, imagem 3 %32
    • Get the epoxy ready by pouring it into a plate.
    • Use a toothpick to apply epoxy into the part of the club head that goes over the shaft.
  7. Golf Club Shaft Replacement: passo 7, imagem 1 %32 Golf Club Shaft Replacement: passo 7, imagem 2 %32 Golf Club Shaft Replacement: passo 7, imagem 3 %32
    • Slide the new shaft into the club head.
    • Wipe off the excess epoxy that squeezes out.
    • Let the epoxy set overnight for an optimal seal, then it will be ready for use.
Linha de Chegada
Uma outra pessoa concluiu este guia.
George Bassili
Membro desde: 04/30/21
166 Reputação
Autoria de 1 guia
Equipe
0 comentários
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 1
Últimos 7 dias: 10
Últimos 30 dias: 62
Duração total: 1,329
