Ir para o conteúdo principal
Golf Club Grip Replacement
O que você precisa
  1. Golf Club Grip Replacement, Grip: passo 1, imagem 1 %32 Golf Club Grip Replacement, Grip: passo 1, imagem 2 %32
    • Place the golf club securely on a level table.
    • Using a blade or knife, cut a line through the grip.
  2. Golf Club Grip Replacement: passo 2, imagem 1 %32 Golf Club Grip Replacement: passo 2, imagem 2 %32 Golf Club Grip Replacement: passo 2, imagem 3 %32
    • Remove the grip from the golf club shaft.
  3. Golf Club Grip Replacement: passo 3, imagem 1 %32
    • Use the knife to take off any excess residue from the shaft of the club.
  4. Golf Club Grip Replacement: passo 4, imagem 1 %32 Golf Club Grip Replacement: passo 4, imagem 2 %32
    • Apply the double sided tape to the bare shaft in a spiral pattern.
    • Use the grip to determine how far up the shaft the tape needs to go.
  5. Golf Club Grip Replacement: passo 5, imagem 1 %32
    • Remove the tape backing.
  6. Golf Club Grip Replacement: passo 6, imagem 1 %32 Golf Club Grip Replacement: passo 6, imagem 2 %32 Golf Club Grip Replacement: passo 6, imagem 3 %32
    • Place a golf tee in the hole at the end of the golf grip.
  7. Golf Club Grip Replacement: passo 7, imagem 1 %32 Golf Club Grip Replacement: passo 7, imagem 2 %32
    • Pour a generous amount of adhesive into the opposite end of the grip.
    • Squeeze together the open end of the grip.
    • Lightly shake, in order to spread the adhesive within the grip.
  8. Golf Club Grip Replacement: passo 8, imagem 1 %32
    • Over a bowl or container, pour adhesive in the grip onto the shaft of the golf club.
  9. Golf Club Grip Replacement: passo 9, imagem 1 %32 Golf Club Grip Replacement: passo 9, imagem 2 %32
    • Remove the tee from the back of the grip.
    • Push the grip onto the golf club shaft.
    • Ensure that the end of the grip is hitting the end of the shaft.
  10. Golf Club Grip Replacement: passo 10, imagem 1 %32
    • Allow to dry at least 12 hours before use.
Conclusão
After allowing the club to properly dry, you will have a new grip to improve your swing at tee off.
6 outras pessoas executaram este guia.
Skylar Nichols
Membro desde: 09/30/16
212 Reputação
Autoria de 1 guia
Equipe
Missouri Western, Team 1-8, Adkins Fall 2016 Membro de Missouri Western, Team 1-8, Adkins Fall 2016
MWSU-ADKINS-F16S1G8
Membros da 3
Autoria de 2 guias
0 comentários
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 2
Últimos 7 dias: 18
Últimos 30 dias: 89
Duração total: 6,892
