Ir para o conteúdo principal
GoPro Karma Stabilizer Replacement
  1. GoPro Karma Stabilizer Replacement, Stabilizer: passo 1, imagem 1 %32 GoPro Karma Stabilizer Replacement, Stabilizer: passo 1, imagem 2 %32 GoPro Karma Stabilizer Replacement, Stabilizer: passo 1, imagem 3 %32
    • Locate stabilizer collar’s unlock and lock symbols. Twist the collar counterclockwise to unlock the stabilizer from GoPro Karma body.
    • Place the GoPro Karma on a stable surface with the legs folded in and the stabilizer facing towards yourself.
  2. GoPro Karma Stabilizer Replacement: passo 2, imagem 1 %32
    • Remove the stabilizer by pulling the entire stabilizer out of the drone body.
Conclusão
Uma outra pessoa concluiu este guia.
Equipe
Cal Poly, Team S25-G14, Maness Spring 2018 Membro de Cal Poly, Team S25-G14, Maness Spring 2018
CPSU-MANESS-S18S25G14
4 Membros
Autoria de 6 guias
1Comentário do guia
My karma got accident and broke two arms on right side. But I tried to start it again and not working anymore.
Friday Aringo - Responder
Comentar
Visualizações:
Últimas 24 horas: 0
Últimos 7 dias: 0
Últimos 30 dias: 4
Ao todo: 1,965
