Ir para o conteúdo principal
GoPro Karma Landing Gear Replacement
O que você precisa
  1. GoPro Karma Landing Gear Replacement, Battery: passo 1, imagem 1 %32
    • Hook your fingers on the tab and pull out the battery.
  2. GoPro Karma Landing Gear Replacement, Stabilizer: passo 2, imagem 1 %32 GoPro Karma Landing Gear Replacement, Stabilizer: passo 2, imagem 2 %32 GoPro Karma Landing Gear Replacement, Stabilizer: passo 2, imagem 3 %32
    • Locate stabilizer collar’s unlock and lock symbols. Twist the collar counterclockwise to unlock the stabilizer from GoPro Karma body.
    • Place the GoPro Karma on a stable surface with the legs folded in and the stabilizer facing towards yourself.
  3. GoPro Karma Landing Gear Replacement: passo 3, imagem 1 %32
    • Remove the stabilizer by pulling the entire stabilizer out of the drone body.
  4. GoPro Karma Landing Gear Replacement, Landing Gear: passo 4, imagem 1 %32
    • Flip the drone upside down with the landing gear out.
    • Remove the four 1.2 cm long hex screws with a Hex 2.0 screwdriver in the four corners of the landing gear
  5. GoPro Karma Landing Gear Replacement: passo 5, imagem 1 %32
    • Push with your thumb and pull up with your fingers to remove the landing gear.
    • Caution: The landing gear is connected by a thin cable so do not pull too far away.
  6. GoPro Karma Landing Gear Replacement: passo 6, imagem 1 %32 GoPro Karma Landing Gear Replacement: passo 6, imagem 2 %32
    • Flip over the landing gear and locate the cable connector.
    • Use your thumbnail to disconnect the cable and free the landing gear.
Conclusão
Jay Ingram
Membro desde: 04/19/18
334 Reputação
Autoria de 3 guias
Equipe
Cal Poly, Team S25-G14, Maness Spring 2018 Membro de Cal Poly, Team S25-G14, Maness Spring 2018
CPSU-MANESS-S18S25G14
4 Membros
Autoria de 6 guias
0 comentários
Comentar
Exibir estatísticas:
Últimas 24 horas: 0
Últimos 7 dias: 2
Últimos 30 dias: 4
Ao todo: 636
