Ir para o conteúdo principal
GoPro Hero5 Black Back Housing Replacement
O que você precisa
  1. GoPro Hero5 Black Back Housing Replacement, Battery: passo 1, imagem 1 %32 GoPro Hero5 Black Back Housing Replacement, Battery: passo 1, imagem 2 %32 GoPro Hero5 Black Back Housing Replacement, Battery: passo 1, imagem 3 %32
    • While pressing the button on the bottom of the GoPro, slide the battery door to the side to pop it open.
  2. GoPro Hero5 Black Back Housing Replacement: passo 2, imagem 1 %32 GoPro Hero5 Black Back Housing Replacement: passo 2, imagem 2 %32 GoPro Hero5 Black Back Housing Replacement: passo 2, imagem 3 %32
    • Grab the plastic flap on the battery and pull the battery out.
  3. GoPro Hero5 Black Back Housing Replacement, Back Housing: passo 3, imagem 1 %32 GoPro Hero5 Black Back Housing Replacement, Back Housing: passo 3, imagem 2 %32
    • Pull and twist the lens cover right or left until it pops off.
    • The lens cover is secured tightly and might be difficult to twist off.
    レンズを回すには爪などをレンズカバーと本体との隙間に入れて、手前に引き出してから回転させます。
    Taizo Yamamoto - Responder
    Go around the gap between the lens cover and camera body with a thin spludger to open a small gap and the cover will twist off easily.
    Paul - Responder
  4. GoPro Hero5 Black Back Housing Replacement: passo 4, imagem 1 %32
    • This step is not necessary but will make the process of removing the faceplate much easier.
    • Refer to the iOpener instructions for how to heat up and use the iOpener.
    • Apply the heated iOpener to the front of the GoPro for a few minutes to melt the adhesive under the faceplate.
    • The heated iOpener is very hot and can burn your hands. Avoid burns by using towels or gloves to hold the iOpener.
  5. GoPro Hero5 Black Back Housing Replacement: passo 5, imagem 1 %32 GoPro Hero5 Black Back Housing Replacement: passo 5, imagem 2 %32 GoPro Hero5 Black Back Housing Replacement: passo 5, imagem 3 %32
    • Starting with the edges, use the spudger to pry off the faceplate.
    • The faceplate is held down with adhesive and may take a while to get off.
  6. GoPro Hero5 Black Back Housing Replacement: passo 6, imagem 1 %32 GoPro Hero5 Black Back Housing Replacement: passo 6, imagem 2 %32
    • Remove the six T3 Torx screws.
    Where can I get the screw driver
    subashzeeq - Responder
    Mine are actually T4 screws.
    John Hahn - Responder
  7. GoPro Hero5 Black Back Housing Replacement: passo 7, imagem 1 %32 GoPro Hero5 Black Back Housing Replacement: passo 7, imagem 2 %32 GoPro Hero5 Black Back Housing Replacement: passo 7, imagem 3 %32
    • Be careful when pulling open the motherboard assembly as it is still connected to the back housing by four cables. The cables may break if stretched.
    • Using the spudger, slowly pry open the motherboard assembly from the LCD side of the GoPro.
    Little FYI ; pry slightly on the side with the LCD. Once it pops, work the other slightly. Then pull the board up and out but remember the cables. THE PICTURE ABOVE WHERE THE METAL SHIELD IS IS THE CAMERA LENS! CABLES ARE ON THE SIDE WHERE YOU BEGIN PRYING.
    stevan othon - Responder
  8. GoPro Hero5 Black Back Housing Replacement: passo 8, imagem 1 %32 GoPro Hero5 Black Back Housing Replacement: passo 8, imagem 2 %32 GoPro Hero5 Black Back Housing Replacement: passo 8, imagem 3 %32
    • Use the flat end of a spudger to pry the three ribbon cables connected to the side of the motherboard.
  9. GoPro Hero5 Black Back Housing Replacement: passo 9, imagem 1 %32 GoPro Hero5 Black Back Housing Replacement: passo 9, imagem 2 %32
    • Use the flat end of the spudger to pry the battery housing power cable straight up from its socket on the motherboard.
    Does anyone know which are the specs of the connector/socket? Thanks
    Pietro De Caro - Responder
Conclusão
16 outras pessoas executaram este guia.
Christopher Adams
Membro desde: 10/03/16
2.091 Reputação
Autoria de 5 guias
Equipe
Cal Poly, Team 18-6, Forte Fall 2016 Membro de Cal Poly, Team 18-6, Forte Fall 2016
CPSU-FORTE-F16S18G6
Membros da 4
Autoria de 22 guias
2 comentários
Where can you get replacement rear screens for this
ociaravella - Responder
Hi, how i reset firmware in this gopro? I have a problem with a bucle starting and it dont turn on, always restarting.
ISU AREY - Responder
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 4
Últimos 7 dias: 21
Últimos 30 dias: 118
Duração total: 23,173
