Introdução
Use this guide to replace a malfunctioning motherboard or expansion port. Because replacing either part requires the same steps, they are both combined into one guide.
O que você precisa
Using a plastic opening tool, separate the camera sensor's connector from the motherboard.
Using #00 phillips head screwdriver, remove the 3.0mm screw.
Using the plastic opening tool, unclip the LCD ribbon from the motherboard.
9 outras pessoas executaram este guia.
Um comentário
step 2 is wrong, short screw belongs on the battery door edge... destroyed my new housing... :(
